メインコンテンツにスキップ
Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement
必要な工具と部品
  1. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the sprocket guard plate: 手順 1、 1の画像 1
    • Use a 13 mm socket to remove the two nuts securing the sprocket guard plate.
  2. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 手順 2、 1の画像 1
    • Remove the sprocket guard plate.
  3. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the chain and guide bar: 手順 3、 1の画像 1
    • If the chainsaw has a chain and guide bar installed, follow the manufacturer's instructions and remove them before proceeding.
    • During reassembly, if you are reinstalling the chain and guide bar, follow the manufacturers instructions on proper chain tensioning techniques.
  4. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the chain brake cover: 手順 4、 1の画像 1
    • Remove the four 12 mm long T27 screws securing the chain brake cover.
  5. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 手順 5、 1の画像 1
    • Remove the chain brake cover.
  6. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the tensioner assembly: 手順 6、 1の画像 1
    • Twist the tension screw clockwise until the slide bar stops at the right end.
    • Remove the single 15.7 mm long T27 screw holding the chain tensioner assembly in place.
  7. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 手順 7、 1の画像 1
    • Use your fingers to pull the assembly out of its recess and remove it.
  8. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 手順 8、 1の画像 1
    • If the packing ring did not come out with the assembly, remove it from the recess.
  9. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Assemble the replacement tensioner: 手順 9、 1の画像 1
    • The next three steps show how to prepare the new tensioning assembly for replacement.
    • Lightly lubricate the packing ring and press it into the back of the adjustment screw.
  10. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 手順 10、 1の画像 1
    • Slide the adjustment screw into the tensioning assembly such that the gears mesh together.
  11. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 手順 11、 1の画像 1
    • Slide the shaped plastic bearing onto the end of the assembly.
    • Lightly lubricate all moving surfaces.
  12. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 手順 12、 1の画像 1
    • Line up the tensioning assembly with its recess in the chainsaw and push it into the recess.
    • Make sure that the black plastic bearing slides in rounded-edge first.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Arthur Shi
メンバー登録日: 01/03/18
254,076 ポイント
529のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
17,277のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 48
今までの合計 2,365
