メインコンテンツにスキップ
Making a low cost photography light stand
必要な工具と部品
  1. Making a low cost photography light stand, Unplug the lamp: 手順 1、 1の画像 1
    • Before disassembling on the lamp, it MUST be unplugged!
  2. Making a low cost photography light stand, Remove the lightbulb: 手順 2、 3の画像 1 Making a low cost photography light stand, Remove the lightbulb: 手順 2、 3の画像 2 Making a low cost photography light stand, Remove the lightbulb: 手順 2、 3の画像 3
    • If the bulb is worth keeping, this can be reused.
    • If the lamp has a lightbulb installed, remove it from the lamp.
  3. Making a low cost photography light stand, Remove the socket cover: 手順 3、 3の画像 1 Making a low cost photography light stand, Remove the socket cover: 手順 3、 3の画像 2 Making a low cost photography light stand, Remove the socket cover: 手順 3、 3の画像 3
    • MOST LAMPS WILL BE SIMILAR, but designs can vary.
    • Remove the switch handle. Note: While this can be optional, it was required on this lamp. If it looks tied into something, it probably has to be removed.
    • Remove the socket cover. Once removed, remove the bulb socket.
  4. Making a low cost photography light stand, Remove the bulb socket: 手順 4、 2の画像 1 Making a low cost photography light stand, Remove the bulb socket: 手順 4、 2の画像 2
    • Sockets that hold the cord in with a press-fit design are hard to reuse by design. Unless you can depress the cord, cut the cord at the socket and discard the bulb socket.
    • After removing the plastic cover and switch, remove the bulb socket with a Phillips #2 screwdriver. If your socket is press fit, these are generally not reusable. Cut the cord unless you can pull the cord and not compromise the socket.
    • Discard any broken or unwanted components.
  5. Making a low cost photography light stand, Remove the cord: 手順 5、 3の画像 1 Making a low cost photography light stand, Remove the cord: 手順 5、 3の画像 2 Making a low cost photography light stand, Remove the cord: 手順 5、 3の画像 3
    • Keep the cord if it is in good shape. These are excellent to keep around to repair other lamps (or anything in need of a similar cord).
    • After removing the bulb socket, remove the power cord.
  6. Making a low cost photography light stand, Test the lamp and find a good clamp point: 手順 6、 1の画像 1
    • After gutting the lamp, find a good spot to clamp a workshop light on like the one shown. Additional changes like height reduction can also be done at this stage.
ゴール
作成者
3人の作成者と共同で作成されました。
Nick
メンバー登録日: 11/10/09
93,746 ポイント
59のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
326 メンバー
1,672のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 547
