はじめに
If you have message "Camera failed"
First of all try this: Open Camera app from the "Application manager" and do "Clear data", then restart the phone.
Second: Do a Factory reset (of course save your data!).
Third: Reinstall Android OS.
If this not help you, you have a hardware problem. You need to change the camera.
Also you can test the camera from the Hidden / Test menu. Enter this code at the dealer: *#0*#
See also: Samsung Galaxy S4の背面カメラの交換
必要な工具と部品
ビデオの概要
Use the flat end of a spudger to disconnect the rear-facing camera connector.
7 の人々がこのガイドを完成させました。
