メインコンテンツにスキップ
Magellan RoadMate 5236T-LM Speaker Replacement
必要な工具と部品
  1. Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: 手順 1、 3の画像 1 Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: 手順 1、 3の画像 2 Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: 手順 1、 3の画像 3
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Speaker Replacement: 手順 2、 3の画像 1 Magellan RoadMate 5236T-LM Speaker Replacement: 手順 2、 3の画像 2 Magellan RoadMate 5236T-LM Speaker Replacement: 手順 2、 3の画像 3
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Speaker Replacement: 手順 3、 2の画像 1 Magellan RoadMate 5236T-LM Speaker Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Speaker Replacement, Speaker: 手順 4、 2の画像 1 Magellan RoadMate 5236T-LM Speaker Replacement, Speaker: 手順 4、 2の画像 2
    • Lay the back panel on a flat surface with the battery, motherboard, and speaker facing up.
    • Use a plastic opening tool to gently pull the battery away from the back panel in order to remove the adhesive that helps the battery stick to the panel.
  5. Magellan RoadMate 5236T-LM Speaker Replacement: 手順 5、 1の画像 1
    • Unscrew the two 5mm screws using a Phillips #000 screwdriver.
  6. Magellan RoadMate 5236T-LM Speaker Replacement: 手順 6、 3の画像 1 Magellan RoadMate 5236T-LM Speaker Replacement: 手順 6、 3の画像 2 Magellan RoadMate 5236T-LM Speaker Replacement: 手順 6、 3の画像 3
    • Use a Phillips #000 screwdriver to remove three 5mm screws that hold the motherboard down to the the back panel.
    • Remove the battery, speaker and motherboard. Place them on a flat surface upside down.
  7. Magellan RoadMate 5236T-LM Speaker Replacement: 手順 7、 1の画像 1
終わりに
作成者
2人の作成者と共同で作成されました。
Felix Muwanguzi
メンバー登録日: 10/24/16
199 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 4-7, Catania Fall 2016 UMass Dartmouth, Team 4-7, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S4G7
3 メンバー
5のガイドは作成済み
コメント 1 件
Where can I find a replacement speaker?
Tom Phillips - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 180
