はじめに
When replacing your hard drive, you must transfer the Torx screws from the old drive to the new one.
必要な工具と部品
ビデオの概要
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove two 11 mm Phillips screws securing the hard drive bracket to the upper case.
Remove the two T6 Torx screws from each side of the hard drive (four screws total).
354 の人々がこのガイドを完成させました。
21件のガイドコメント
can i install an ssd instead of a normal hd?
Yes, absolutely. I switched mine out with a Kingston 120GB SSD.
qosmioamit - 共有
