メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
MacBook Pro 17" Unibody Hard Drive Replacement
必要な工具と部品
    1. MacBook Pro 17" Unibody Hard Drive Replacement, Lower Case: 手順 1、 1の画像 1
      • Seven 3 mm Phillips screws.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Pro 17" Unibody Hard Drive Replacement: 手順 2、 2の画像 1 MacBook Pro 17" Unibody Hard Drive Replacement: 手順 2、 2の画像 2
      • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
      • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
      • Remove the lower case.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Pro 17" Unibody Hard Drive Replacement, Battery: 手順 3、 3の画像 1 MacBook Pro 17" Unibody Hard Drive Replacement, Battery: 手順 3、 3の画像 2 MacBook Pro 17" Unibody Hard Drive Replacement, Battery: 手順 3、 3の画像 3
      • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
      • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
      • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
      • Pull the tab parallel to the face of the logic board.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Pro 17" Unibody Hard Drive Replacement, Hard Drive: 手順 4、 1の画像 1
      • Remove the two Phillips screws securing the hard drive bracket to the upper case.
      • These screws are captive to the hard drive bracket.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Pro 17" Unibody Hard Drive Replacement: 手順 5、 1の画像 1
      • Remove the hard drive bracket from the upper case.
      FixBotに聞いてみる
      コメントを追加
    3. MacBook Pro 17" Unibody Hard Drive Replacement: 手順 6、 1の画像 1
      • Use the hard drive's pull tab to lift it out of the upper case.
      • Don't try to completely remove the hard drive just yet! Its cable is still connected.
      FixBotに聞いてみる
      コメントを追加
    4. MacBook Pro 17" Unibody Hard Drive Replacement: 手順 7、 2の画像 1 MacBook Pro 17" Unibody Hard Drive Replacement: 手順 7、 2の画像 2
      • Pull the hard drive connector away from the body of the hard drive.
      • Remove the hard drive from your MacBook Pro.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Pro 17" Unibody Hard Drive Replacement, Hard Drive: 手順 8、 2の画像 1 MacBook Pro 17" Unibody Hard Drive Replacement, Hard Drive: 手順 8、 2の画像 2
      • Remove the four T6 Torx screws around the outer edge of the hard drive.
      • If desired, peel off the plastic pull tab and transfer it to your new hard drive.
      • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
242 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Andrew Bookholt
600,793 ポイント
619のガイドは作成済み
12件のガイドコメント
Very easy to follow. Replacing the HDD on these unibodies is super easy. Thanks for the guide.
tech4eleven - 返信 共有
Very easy, excepted for finding the right screw for Step 8. I replaced original HDD with a Samsung 840 EVO 500GB. Fine!
yello73 - 返信 共有
Exceptional instructions. If you're struggling to restore from a backup... connect your backup drive via cable, start your macbook, choose disk utilities, choose the new hard drive from the list on the left, if first aide options (repair/verify) are not available, erase and name the new drive, and then you should be able to restore from backup. :)
Deanna Ashby - 返信 共有
Thank goodness you posted this. I thought I messed up installation because there was no new HD when I turned on the laptop. I couldn't figure out how to restore. Then I saw this and tried it and it's restoring now. Thank you!!
catchpaco - 返信 共有
Very easy, Thank you for this tremendous guide. Works perfectly and I directly connected my old HDD to USB and restore all my information using the Migration Assistant app. Fine!
Abdullah Alqassar - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 53
過去 30 日: 252
今までの合計 279,478
