このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Remove the following six screws securing the subwoofer and right speaker to the upper case:
Two 3.2 mm ( 3.0 mm ) Phillips screws.
Two 12.3 mm Phillips screws.
One 2.5 mm Phillips screw.
One 8.3 mm ( 8.1 mm ) Phillips screw.
Lift the subwoofer and right speaker assembly out of the upper case.
この手順は未翻訳です。 翻訳を手伝う。
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
33 の人々がこのガイドを完成させました。
10 件のコメント
If your doing this just to replace the keyboard. the keyboard can be replaced after this last step. I found one for $16 on ebay. the only challenge is removing the backlighting which is taped down and then unscrewing about 50 tiny screws to remove the keyboard. the above process takes about an hour and then another hour to just replace the keyboard.
Hi there, I replaced the keyboard on my MacBook pro 15'' mid 2012.
Now my computer turns on but shuts down after a few seconds, except if the charger is plugged in. Do you have any idea what I might have done wrong?
I already did the process 3 times 😥
Thanks,
Marta
marta p -
I completed this replacement successfully, with one glitch and two leftover items. The glitch: I failed to insert the keyboard ribbon cable at first. The leftover items: A multilayer soft pad, silvered, about 3x1 ¾-(7.5x4.5 cm) and a piece of foam in a quarter-round shape, 7/16”(1.2 cm) long, ⅛"(3-4mm) ,on a side, with a fine metal mesh on the long sides. I don’t recall in which step I removed either part. I’m hoping neither is critical, but I’ll replace either as best I can if I’m wrong. I have a photo of the two parts but I don’t see how to add it to the post.
Took me a little over 4 hours, but seems successful. Most of the middle row on my keyboard had stopped working, I was having to use an external. The new case works fine. The hardest part was definitely the logic board removal, but just be patient and methodical and use the spudger to loosen the adhesive that binds the microphone to the upper case. I also encountered two screws that stripped when unscrewing, and had to use some creativity to release those parts. 48 hours after replacement, everything is working, and the new keyboard is definitely an improvement. Time-consuming and stressful but so much cheaper than authorized repair.
