メインコンテンツにスキップ
MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement
必要な工具と部品
  1. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement, Lower Case: 手順 1、 1の画像 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 2、 2の画像 1 MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 2、 2の画像 2
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement, Battery: 手順 3、 1の画像 1
    この手順で使用する道具:
    P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery
    $5.49
    購入する
    • Remove the two 5-Point Pentalobe screws along the top edge of the battery.
    • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
  4. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 4、 1の画像 1
    • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove third five-point Pentalobe screw hidden underneath.
  5. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 5、 2の画像 1 MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 5、 2の画像 2
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
  6. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 6、 1の画像 1
    • Tilt the battery back enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • If you're installing a new battery, you should calibrate it after installation.
  7. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement, Logic Board: 手順 7、 3の画像 1 MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement, Logic Board: 手順 7、 3の画像 2 MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement, Logic Board: 手順 7、 3の画像 3
    • Use a spudger to pry the fan connector straight up off the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  8. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 8、 2の画像 1 MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 8、 2の画像 2
    • Remove the three T6 Torx screws securing the left fan to the logic board.
    • Lift the fan out of the upper case.
  9. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 9、 1の画像 1
    • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
    • Pry up from beneath the wires.
  10. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 10、 2の画像 1 MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 10、 2の画像 2
    • Lift the left fan out of the upper case.
  11. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 11、 1の画像 1
    • The camera cable connector is not secured by any locking or snapping mechanism. Hence, Apple sticks a small strip of black plastic with adhesive applied to the side facing the logic board behind the camera cable connector to keep it in its socket.
    • When moving the strip (cable retainer) out of the way, be sure not to break any surface-mounted components off the logic board.
    • Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
    • Disconnect the camera cable by pulling the male end straight away from its socket.
    • Pull the connector parallel to the face of the logic board, not straight up.
  12. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 12、 1の画像 1
  13. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 13、 1の画像 1
    • Use the flat end of a spudger to pry the optical drive cable connector up off the logic board.
  14. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 14、 1の画像 1
    • Using the flat end of a spudger, pry the subwoofer connector straight up from the connector jack.
    • Be careful to pry the connector, not the socket. It's possible to accidentally pry the socket up from the logic board.
    • Removing the foam applied to the top of the connector will make it easier to see and avoid prying up the socket.
  15. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 15、 1の画像 1
    • Use the flat end of a spudger to pry the hard drive/IR sensor cable connector up off the logic board.
  16. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 16、 2の画像 1 MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 16、 2の画像 2
    • Remove the two 1.5 mm Phillips screws securing the cable cover to the logic board.
    • Lift the cable cover out of the upper case.
  17. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 17、 1の画像 1
    • Use a spudger to pry the trackpad flex ribbon cable connector up off the logic board.
  18. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 18、 2の画像 1 MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 18、 2の画像 2
    • Use your fingernail to flip up the locking flap on the ZIF socket for the keyboard ribbon cable. The locking flap is located at the opposite side of the socket compared to the keyboard ribbon cable. Hook your fingernail under it and carefully lift it up vertically.
    • Do not attempt to slide the keyboard ribbon cable out of its socket before you have unlocked the ZIF socket. Ribbon cables are fragile and excessive force will easily break them.
    • Use the tip of a spudger to slide the keyboard ribbon cable out of its socket.
  19. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 19、 1の画像 1
    • Use a spudger to pry the battery indicator ribbon cable connector up off the logic board.
  20. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 20、 2の画像 1 MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 20、 2の画像 2
    • Remove the single 7 mm Phillips screw securing the display data cable retainer to the upper case.
    • This screw may remain captive in the display data cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Remove the display data cable retainer from the upper case.
  21. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 21、 2の画像 1 MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 21、 2の画像 2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
  22. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 22、 1の画像 1
    • Pull the display data cable connector straight away from its socket.
    • Make sure to pull the connector parallel to the face of the logic board, not straight up from its socket.
  23. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 23、 2の画像 1 MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 23、 2の画像 2
    • Using the tip of a spudger, flip up the keyboard backlight ribbon cable retaining flap.
    • Pull the keyboard backlight ribbon cable straight out of its socket.
  24. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 24、 1の画像 1
    • Remove the following screws:
    • Seven 3.3 mm T6 Torx screws securing the logic board to the upper case.
    • Two 8 mm T6 Torx screws securing the DC-In board to the upper case.
    • Do not remove the logic board yet! There are components on the underside of the logic board attached to the the upper case that must first be disconnected.
  25. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 25、 1の画像 1
    • Carefully lift the logic board assembly from the left side and work it out of the upper case, minding the port side that may get caught during removal.
    • Do not entirely remove the logic board yet!
  26. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 26、 1の画像 1
    • Lift the logic board enough to gain clearance and use a spudger to pry the microphone up off the upper case.
    • Slide the logic board away from the port openings and lift the assembly out of the upper case.
    • Before reinstalling the logic board, it is easiest to press the microphone down into its housing in the left speaker to keep it in place.
  27. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 27、 1の画像 1
  28. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement, Left Speaker: 手順 28、 1の画像 1
    • If your microphone is still inserted into its void in the left speaker housing, use the tip of a spudger to lift it out.
  29. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 29、 1の画像 1
    • Remove the small strip of tape covering the left speaker connector.
  30. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 30、 1の画像 1
    • Use the flat end of a spudger to pry the left speaker connector up off its socket on the logic board.
  31. MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 31、 2の画像 1 MacBook Pro 15" Unibody Mid 2009 Left Speaker Replacement: 手順 31、 2の画像 2
    • Remove the two 5 mm Phillips screws securing the left speaker to the logic board.
    • Lift the left speaker off the logic board.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Andrew Bookholt
586,296 ポイント
619のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 15
今までの合計 9,722
