はじめに
Fans can be such blowhards, except when they blow out. Use this guide to help you replace a damaged, broken, or faulty right fan. This fan is located on the right side of the computer, as seen when it is open and in use.
必要な工具と部品
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
Remove the I/O Board cable from the MacBook Pro.
Remove the single 2.9 mm T5 Torx screw securing the AirPort card to the logic board.
16 の人々がこのガイドを完成させました。
