はじめに
You can install hard drives up to 9.5mm thick.
パーツ
- 320 GB 5400 RPM 2.5" Hard Drive
- 750 GB 7200 RPM Seagate SATA Hard Drive (New)
- MacBook Pro 15" (Model A1211) Hard Drive Cable
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two silver T6 Torx screws and black rubber bumpers from the right side of the hard drive.
578 の人々がこのガイドを完成させました。
19 件のコメント
If your button to open mac is hard to use after you re-assembled the computer, check to see if the proper length screws were reinstalled. I had that problem and I switched the 2 screws. One was a tad longer. The longer one when screwed in, interferred with the button function.
Definitely NOT true for MY Mac. Both screws are absolutely identical. Still I had this issue. :-(
Turned out that if I screw them in real tight the issue will occur. If I turn back the screws about 180 degrees (i. e. if I loosen them) the problem disappears.
