はじめに
SDカードスロット、HDMIポートと右側のUSBポートを含む出入力ボードを交換します。
このガイドはヒートシンクを外さなければなりません。ヒートシンクを再装着する前に、 thermal paste application guide を参照の上、手順に従ってください。
上部ケースと底ケースを留めている次の10本のネジを外します。
  • 上部ケースと底ケースを留めている次の10本のネジを外します。
    • 2.3 mmペンタローブネジ−2本
    • 3.0 mmペンタローブネジー8本
For all the screws you use the P5 pentalobe screwdriver?
Carlos - 返信
Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
Fredrik -
Is the Pentalobe screwdriver mentioned in the tools list? I did not have one so I used a filed down flat blade screwdriver. Not a fantastic idea, but it works.
Alex Birkett - 返信
Yes, it's mentioned on the top of this page. P5 Pentalobe to be precise. I didn't have one either, so I bought one from iFixit and that works fantastic. An absolutely precise fit, which is important especially when you might open your MacBook a couple of times during the years you own it. Not using the correct tool might do more harm to the screws than you want! I once had this with a Lenovo Yoga 3 Pro, which has Torx screws (T4 I think) and I used cheap Chinese quality tools, with the result that both the tool and one of the screws are damaged.
addvariety -
the macbook in the picture is 2012. does it has the same structure as 2013?
Edison - 返信
I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
marketing - 返信
is P5 supposed to be for all 10 screws? it works on the 2x 2.3mm at the top, but not for the 8x others for me. what size screwdriver for the 3mm? thanks
monsieurescargot - 返信
Yes, the p5 works for all 10 pentalobe screw heads for bottom cover. The the different size mm reference only refers to the difference in length of the screws, but again both heads are p5.
Antoine Thornton - 返信
上部ケースと底ケースの間に指を差し込みます。
  • 上部ケースと底ケースの間に指を差し込みます。
  • ゆっくりと底ケースを上部ケースから離していきます。
コメントを追加する
底ケースは上部ケースと2つのプラスチック製クリップで中央付近に接続されています。 再組み立ての際は、丁寧に底ケースの中央を2つのプラスチック製クリップに接続するように押し込んでください。
  • 底ケースは上部ケースと2つのプラスチック製クリップで中央付近に接続されています。
  • 再組み立ての際は、丁寧に底ケースの中央を2つのプラスチック製クリップに接続するように押し込んでください。
There are two screws that are shorter-they go to the back near the vent.
wrbandllm - 返信
This was already mentioned at the start, it says 2x 2.3mm screws and those are coloured red instead of orange for the other ones in iFixit's image.
addvariety - 返信
What is the black vinyl-y sticker on the inside of the case (some sort of shield?). I was forced to slightly puncture it in order to replace the feet on my laptop. Thanks in advance.
Tommy Huang - 返信
必要に応じてバッテリーの接続ボードに留められているプラスチック製カバーを外してください。
  • 必要に応じてバッテリーの接続ボードに留められているプラスチック製カバーを外してください。
コメントを追加する
スパッジャーの平面側先端を使って、バッテリーコネクターをロジックボード上のソケットからまっすぐ持ち上げます。 コネクターのみ持ち上げるよう確認しながら作業を進めてください。ソケットには接触しないでください。ロジックボードに永久的なダメージを与えてしまうことがあります。
  • スパッジャーの平面側先端を使って、バッテリーコネクターをロジックボード上のソケットからまっすぐ持ち上げます。
  • コネクターのみ持ち上げるよう確認しながら作業を進めてください。ソケットには接触しないでください。ロジックボードに永久的なダメージを与えてしまうことがあります。
I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
jramsey21 - 返信
I have the some problem. I was thinking to replace the whole battery but I am not it will solve the problem. Any suggestions?
salvatorebarbera -
Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
andrehedegaard -
Have either of you replaced the battery and/or circuit board to fix the MacBooks with the water damage ? I have the same problem with the MacBook working fine when connected to power but dying immediately when the power cord is removed.
Steve - 返信
Hi, Steve. I had the same problem: Macbook Pro 15 retina with coffee damage. And it worked fine when connected to power. I made it working after replacing the whole battery. It seems that circuit connected to the battery becomes disabled to prevent short circuit.
Vadim Gribanov -
When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
Ethan Tarquin - 返信
Thanks for the comment. My MBP isn’t powering on after I walked through these steps, and I assume it is because the battery connector isn’t fully connected. (I can’t check yet since I borrowed the pentalobe screwdriver)
Caleb Steinborn -
+1
I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
Jonas Ehrs -
If I only want to replace the trackpad cable, then which steps should I skip? This step seems unnecessary
Parth Gudhka - 返信
修理作業中、アクシデントによりソケットがバッテリーコネクターに接続しないよう、折り曲げて邪魔にならない位置に移動させてください。
  • 修理作業中、アクシデントによりソケットがバッテリーコネクターに接続しないよう、折り曲げて邪魔にならない位置に移動させてください。
If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
sebasgaes - 返信
I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
LaymanLab - 返信
That’s a great idea!
David Lilliebridge - 返信
ヒートシンクの端からゴム製のファン用バンパーを丁寧に取り出します。 ファン用バンパーはヒートシンクの周りに巻かれており、ファンダクトの溝に装着されています。再組み立ての際は、ファンダクトの切り込みにタブが正確に装着されているか確認してください。 ファン用バンパーはヒートシンクの周りに巻かれており、ファンダクトの溝に装着されています。再組み立ての際は、ファンダクトの切り込みにタブが正確に装着されているか確認してください。
  • ヒートシンクの端からゴム製のファン用バンパーを丁寧に取り出します。
  • ファン用バンパーはヒートシンクの周りに巻かれており、ファンダクトの溝に装着されています。再組み立ての際は、ファンダクトの切り込みにタブが正確に装着されているか確認してください。
コメントを追加する
スパッジャーの平面側先端を使って、ヒートシンクネジから4つのフォーム製のステッカーを剥がします。 スパッジャーの平面側先端を使って、ヒートシンクネジから4つのフォーム製のステッカーを剥がします。
  • スパッジャーの平面側先端を使って、ヒートシンクネジから4つのフォーム製のステッカーを剥がします。
How should I reapply those little foam stickers? I guess not with normal glue.
bboy.sidekick - 返信
ロジックボードに留められたヒートシンクから次の4つのネジを取り出します。
  • ロジックボードに留められたヒートシンクから次の4つのネジを取り出します。
    • 2.6 mm T5トルクスネジー4本
    • 2.4 mm #000 プラスネジー1本
コメントを追加する
ラップトップからヒートシンクを取り出します。 コンピューターを再組み立てする際は、放熱グリスの装着手順に従って、放熱グリスを付けてください。
  • ラップトップからヒートシンクを取り出します。
  • コンピューターを再組み立てする際は、放熱グリスの装着手順に従って、放熱グリスを付けてください。
コメントを追加する
スパッジャーの先端を使って、ロジックボード上のソケットから接続を外すため、iSightカメラケーブルコネクターを外側へ押し出します。 スパッジャーの先端を使って、ロジックボード上のソケットから接続を外すため、iSightカメラケーブルコネクターを外側へ押し出します。
  • スパッジャーの先端を使って、ロジックボード上のソケットから接続を外すため、iSightカメラケーブルコネクターを外側へ押し出します。
I found this to be the most difficult step. There is a need to get positioned so that you have the leverage to push hard enough at exactly the point shown in the photo without risking slipping and perhaps damaging the CPU nearby
Tony M - 返信
iSightカメラのケーブルを内蔵ファンから取り出して、作業の邪魔にならないように折り曲げます。 iSightカメラのケーブルを内蔵ファンから取り出して、作業の邪魔にならないように折り曲げます。
  • iSightカメラのケーブルを内蔵ファンから取り出して、作業の邪魔にならないように折り曲げます。
コメントを追加する
スパッジャーの先端を使って、ZIFコネクター上のタブを上向きに折り曲げます。 ファンケーブルをソケットからまっすぐ引き上げて外します。 ファンケーブルをソケットからまっすぐ引き上げて外します。
  • スパッジャーの先端を使って、ZIFコネクター上のタブを上向きに折り曲げます。
  • ファンケーブルをソケットからまっすぐ引き上げて外します。
my cable was glued, had to be pryed up first.
maccentric - 返信
上部ケースに留められたファンから次のネジを外します。
  • 上部ケースに留められたファンから次のネジを外します。
    • 5.0 mm T5トルクスネジー1本
    • 3.6 mm T5トルクスネジー2本
コメントを追加する
ディスプレイの丁番に近いファンの先端を持ち上げて、上部ケースからファンを外します。 ディスプレイの丁番に近いファンの先端を持ち上げて、上部ケースからファンを外します。 ディスプレイの丁番に近いファンの先端を持ち上げて、上部ケースからファンを外します。
  • ディスプレイの丁番に近いファンの先端を持ち上げて、上部ケースからファンを外します。
コメントを追加する
コネクター付近のアンテナケーブルの下にスパッジャーの先端を差し込み、AirPort ボードの接続を外します。 3本のケーブルは長さの異なる黒色のスリーブでコーテイングされています。再組み立ての際は次の点にご注意ください。 一番長いスリーブケーブルは中央のソケットに接続します。
  • コネクター付近のアンテナケーブルの下にスパッジャーの先端を差し込み、AirPort ボードの接続を外します。
  • 3本のケーブルは長さの異なる黒色のスリーブでコーテイングされています。再組み立ての際は次の点にご注意ください。
    • 一番長いスリーブケーブルは中央のソケットに接続します。
    • 一番短いスリーブケーブルはネジの隣に接続します。
    • 最後のケーブルはスリーブが付いていません。最後に残っているファンの隣のソケットに接続します。
コメントを追加する
出入力ケーブルブラケットに留められた2.1 mm T5トルクスネジを2本外します。 出入力ボードのケーブルブラケットを外します。
  • 出入力ケーブルブラケットに留められた2.1 mm T5トルクスネジを2本外します。
  • 出入力ボードのケーブルブラケットを外します。
コメントを追加する
スパッジャーの平面側先端を使って、出入力ボードのコネクターを出入力ボード上のソケットからまっすぐ引き上げます。 ケーブルコネクターのみ持ち上げるように作業には注意を払ってください。ソケット自体には接触しないでください。出入力ボードにダメージを与えてしまうことがあります。 出入力ボードケーブルを作業の邪魔にならない位置に折り曲げます。
  • スパッジャーの平面側先端を使って、出入力ボードのコネクターを出入力ボード上のソケットからまっすぐ引き上げます。
  • ケーブルコネクターのみ持ち上げるように作業には注意を払ってください。ソケット自体には接触しないでください。出入力ボードにダメージを与えてしまうことがあります。
  • 出入力ボードケーブルを作業の邪魔にならない位置に折り曲げます。
コメントを追加する
スパッジャーの先端を使って、出入力ボードコネクターの両側を押し出し、ロジックボード上のソケットから外します。 スパッジャーの先端を使って、出入力ボードコネクターの両側を押し出し、ロジックボード上のソケットから外します。
  • スパッジャーの先端を使って、出入力ボードコネクターの両側を押し出し、ロジックボード上のソケットから外します。
コメントを追加する
上部ケースに留められた出入力ボードから次のネジを外します。
  • 上部ケースに留められた出入力ボードから次のネジを外します。
    • 3.5 mm T9トルクススタンドオフネジー1本
    • 3.5 mm T5トルクスネジー1本
コメントを追加する
上部ケースからポートを外すため、出入力ボードの出入力ボードケーブル先端を持ち上げてロジックボード側に引っ張ります。 出入力ボードを取り出します。 出入力ボードを取り出します。
  • 上部ケースからポートを外すため、出入力ボードの出入力ボードケーブル先端を持ち上げてロジックボード側に引っ張ります。
  • 出入力ボードを取り出します。
コメントを追加する
出入力ボードに留められたAirPortボードから2.7 mm T5トルクスネジを1本外します。
  • 出入力ボードに留められたAirPortボードから2.7 mm T5トルクスネジを1本外します。
コメントを追加する
AirPort ボードを外すため、先端を持ち上げて出入力ボード上のソケットから AirPort ボードを引っ張ります。 AirPort ボードを外すため、先端を持ち上げて出入力ボード上のソケットから AirPort ボードを引っ張ります。 AirPort ボードを外すため、先端を持ち上げて出入力ボード上のソケットから AirPort ボードを引っ張ります。
  • AirPort ボードを外すため、先端を持ち上げて出入力ボード上のソケットから AirPort ボードを引っ張ります。
コメントを追加する
まとめ
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
5 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Midori Doiさんは世界中で修理する私たちを助けてくれています! 貢献してみませんか?
翻訳を始める ›
Sam Lionheart
メンバー登録日: 2012年10月18日
314,660 ポイント
1,640のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
116 メンバー
5,773のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 4
過去 7 日: 27
過去 30 日: 181
今までの合計 17,613
