はじめに
Use this guide to replace a faulty logic board.
Don't forget to follow our thermal paste application guide before you reinstall your heat sink.
必要な工具と部品
この手順で使用する道具:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
Remove the I/O board cable bracket.
133 の人々がこのガイドを完成させました。
21 件のコメント
I did not need to remove the heat sink. You can simply remove part of the fan assembly in about 1 minute and the heat sink and its associated arm with fins comes right out. Removing the heat sink introduces unnecessary complications that could destroy your logic board should you perform an incorrect repair on the thermal paste.
Any instructions and images demonstrating this?
Richard -
Only part i am missing is how to give the new board it's serial number
me too,me too,
