はじめに
Use this guide to replace the MagSafe DC-In board.
必要な工具と部品
この手順で使用する道具:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Remove the following screws securing the heat sink to the logic board assembly:
One 2.4 mm Phillips #00 screw
One 3.4 mm T5 Torx screw
Four 2.7 mm T5 Torx screws
Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
Pull the right fan ribbon cable straight out of its socket on the logic board.
Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
Use the tip of a spudger to push the edges of the I/O board connector straight out of its socket on the logic board.
Gently push the edges of the MagSafe cable connector away from its socket on the logic board.
9 の人々がこのガイドを完成させました。
2 件のコメント
Thanks a lot for this guide ! I completed it with no problems… I never did this kind of unmount/repair and thanks to the iFixit Essential Electronics Toolkit, ++Arctic Silver Thermal Paste++ and Arctic Silver ArctiClean it was a breeze to complete. I think I have put too much thermal paste but it is no problem. The macbook now works like a charm.
Missing instructions on how to remove iSight camera cord during removal of right fan.
You can find it under step 15 of the logic board removal.
Otherwise so far it’s a great tutorial.
