メインコンテンツにスキップ
MacBook Core Duo Left Hinge Mount Replacement
必要な工具と部品
  1. MacBook Core Duo Left Hinge Mount Replacement, Battery: 手順 1、 1の画像 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core Duo Left Hinge Mount Replacement: 手順 2、 1の画像 1
    • Lift the battery out of the computer.
  3. MacBook Core Duo Left Hinge Mount Replacement, Memory Cover: 手順 3、 1の画像 1
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
  4. MacBook Core Duo Left Hinge Mount Replacement: 手順 4、 1の画像 1
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
  5. MacBook Core Duo Left Hinge Mount Replacement, Upper Case: 手順 5、 1の画像 1
    • Remove the following 3 screws:
    • One 11 mm Phillips #00 in the middle of the case.
    • Two 14.5 mm Phillips #00.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
  6. MacBook Core Duo Left Hinge Mount Replacement: 手順 6、 1の画像 1
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
    • One 4 mm Phillips #00 on the right side.
    • When reinstalling these screws, press gently on the lower case to line up the screw holes.
    • These screws easily strip, so be careful while taking these particular screws out.
  7. MacBook Core Duo Left Hinge Mount Replacement: 手順 7、 1の画像 1
    • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
  8. MacBook Core Duo Left Hinge Mount Replacement: 手順 8、 1の画像 1
    • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
  9. MacBook Core Duo Left Hinge Mount Replacement: 手順 9、 1の画像 1
    • Remove the following 4 screws from the back of the computer:
    • Two 7 mm shouldered Phillips on the far sides.
    • Two 10.5 mm Phillips toward the center.
    • Do not over-tighten these; you can cause the case to distort.
  10. MacBook Core Duo Left Hinge Mount Replacement: 手順 10、 1の画像 1
    • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
    • It is not necessary to remove the similar screws on the other side of the computer.
  11. MacBook Core Duo Left Hinge Mount Replacement: 手順 11、 1の画像 1
    • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
    • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
  12. MacBook Core Duo Left Hinge Mount Replacement: 手順 12、 1の画像 1
    • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
    • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
    • Do not pry from the bottom or the top, but from the sides.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
  13. MacBook Core Duo Left Hinge Mount Replacement, Left Hinge Mount: 手順 13、 1の画像 1
    • Remove the following 3 screws from the left hinge mount:
    • One 6 mm smaller diameter Phillips from the right side.
    • One 6 mm larger diameter Phillips from the middle.
    • One 10 mm Phillips from the left side.
    • Lift the hinge mount and attached plastic dust cover out of the computer.
  14. MacBook Core Duo Left Hinge Mount Replacement: 手順 14、 1の画像 1
    • Slide the plastic dust cover out of its slot in the left hinge mount.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
635のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 7
今までの合計 12,066
