メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
MacBook Core 2 Duo Upper Case Replacement
必要な工具と部品
    1. MacBook Core 2 Duo Upper Case Replacement, Battery: 手順 1、 1の画像 1
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Core 2 Duo Upper Case Replacement: 手順 2、 1の画像 1
      • Lift the battery out of the computer.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Core 2 Duo Upper Case Replacement, Memory Cover: 手順 3、 1の画像 1
      • Unscrew the three evenly-spaced Phillips 000 screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover so you cannot lose them.
      • Using The Flexible Extension sold by iFixit will help with this step.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Core 2 Duo Upper Case Replacement: 手順 4、 1の画像 1
      • Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
      • Lift the memory cover up and out of the computer.
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Core 2 Duo Upper Case Replacement, Upper Case: 手順 5、 1の画像 1
      • Remove the following 3 screws:
      • One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
      • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle of the lower case.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Core 2 Duo Upper Case Replacement: 手順 6、 1の画像 1
      • Take extra caution with these screws as they can strip easily!
      • You could use a flexible extension to minimize stripping.
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
      • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
      FixBotに聞いてみる
      コメントを追加
    3. MacBook Core 2 Duo Upper Case Replacement: 手順 7、 1の画像 1
      • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
      FixBotに聞いてみる
      コメントを追加
    4. MacBook Core 2 Duo Upper Case Replacement: 手順 8、 1の画像 1
      • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screws.
      • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
      FixBotに聞いてみる
      コメントを追加
    5. MacBook Core 2 Duo Upper Case Replacement: 手順 9、 1の画像 1
      • Remove the following 4 screws from the back of the computer:
      • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
      • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
      • During reassembly, the two longer screws go on the inside, and the two shorter screws go on the outside.
      FixBotに聞いてみる
      コメントを追加
    6. MacBook Core 2 Duo Upper Case Replacement: 手順 10、 1の画像 1
      • Remove the two Phillips screws from the optical drive (right) side of the computer:
      • Two 5.2 mm Phillips #00, with shank (2.3mm dia. x 3.25 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
      • It is not necessary to remove the similar screws on the ports (left) side of the computer.
      FixBotに聞いてみる
      コメントを追加
    7. MacBook Core 2 Duo Upper Case Replacement: 手順 11、 1の画像 1
      この手順で使用する道具:
      Plastic Cards
      $2.99
      • There's a trackpad and keyboard ribbon cable connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
      • The upper case is likely to stick at its connection above the front edge of the optical drive. If this happens, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening. Here again, inserting a plastic card, guitar pick, etc. can be useful.
      • If you stand the base of the MacBook on one end to get a better look, you may displace the four grey plastic clips that hold the right side of the upper case in place. Don't panic. They slide into slots at the top rightmost edge of the lower frame, above the front edge of the optical drive.
      • During reassembly, make sure the clips on the right side, above the optical drive, click firmly into place. They're different from the clips on the left side, and so normally they require a little firmer pressure to click into place.
      FixBotに聞いてみる
      コメントを追加
    8. MacBook Core 2 Duo Upper Case Replacement: 手順 12、 3の画像 1 MacBook Core 2 Duo Upper Case Replacement: 手順 12、 3の画像 2 MacBook Core 2 Duo Upper Case Replacement: 手順 12、 3の画像 3
      • While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
      • If there is no black tab, you can also use a spudger to gently pry the connector out of its socket on the logic board. This connector is tall, so be sure to pry straight up.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      • While you have the upper case removed, it's a good time to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
      • Upon reassembly, there are 4 grey plastic clips installed in slots running along the top of the frame in front of the optical drive (refer to second and third pictures). These clips must be installed in their slots for their mating tabs on the underside of the right side of the upper case to snap into them.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
409 の人々がこのガイドを完成させました。
作成者
36人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
632のガイドは作成済み
14件のガイドコメント
Note that the actual keyboard is sandwiched between the top case and an aluminum backing panel that is plastic welded together. Because of this, the keyboard can not be replaced without modification to these plastic weld points.
I actually purchased a replacement keyboard only to find out that I should have purchased the whole top case unit.
Keil Miller - 返信 共有
Many thanks for this guide. I was able to replace my old fried keyboard with no problem!
LividFiction - 返信 共有
Wow. I have used this guide religiously 3 times now and I can not thank enough for it to the provider. You won't find anything more informative, explicit, graphic, descriptive but simple and basic oriented out there, and without leaving key details out. I think you did a FANTASTIC job with this guide, and thank you again. I'm very happy I found this link.
By the way, much better and appropiate than those dozens of youtube videos.
David - 返信 共有
On step 10 the last screw, the one farthest away from the optical drive, would not come out. My screw driver is fine and the screw look ok but it will not come out. I'v been trying for 30 minutes now.
Aidan Morey - 返信 共有
hello staff ifixit
I have a question happens when I change the upper case of this team and still does not work bring it to a central apple and tell me I have to change the logic board is this true and if so how is that is damaged
David chunga - 返信 共有
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 51
過去 30 日: 226
今までの合計 395,932
