メインコンテンツにスキップ
MacBook Air 2022 (M2) MagSafe Port Replacement
必要な工具と部品
  1. MacBook Air 2022 (M2) MagSafe Port Replacement, Prepare your Macbook Air for disassembly: 手順 1、 3の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Prepare your Macbook Air for disassembly: 手順 1、 3の画像 2 MacBook Air 2022 (M2) MagSafe Port Replacement, Prepare your Macbook Air for disassembly: 手順 1、 3の画像 3
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your MacBook Air and unplug all cables.
    • Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
  2. MacBook Air 2022 (M2) MagSafe Port Replacement, Unfasten the lower case: 手順 2、 2の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Unfasten the lower case: 手順 2、 2の画像 2
    この手順で使用する道具:
    FixMat
    $36.95
    購入する
    • Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
    • Two screws with a short threaded portion near the hinges
    • Two screws with a long threaded portion near the front of the MacBook
  3. MacBook Air 2022 (M2) MagSafe Port Replacement, Insert an opening pick: 手順 3、 3の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Insert an opening pick: 手順 3、 3の画像 2 MacBook Air 2022 (M2) MagSafe Port Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. MacBook Air 2022 (M2) MagSafe Port Replacement, Release the snapping clips: 手順 4、 3の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Release the snapping clips: 手順 4、 3の画像 2 MacBook Air 2022 (M2) MagSafe Port Replacement, Release the snapping clips: 手順 4、 3の画像 3
    • During the next two steps you'll feel and hear four snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next two clips.
  5. MacBook Air 2022 (M2) MagSafe Port Replacement: 手順 5、 3の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement: 手順 5、 3の画像 2 MacBook Air 2022 (M2) MagSafe Port Replacement: 手順 5、 3の画像 3
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the three remaining snapping clips.
  6. MacBook Air 2022 (M2) MagSafe Port Replacement, Release the sliding tabs: 手順 6、 3の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Release the sliding tabs: 手順 6、 3の画像 2 MacBook Air 2022 (M2) MagSafe Port Replacement, Release the sliding tabs: 手順 6、 3の画像 3
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. MacBook Air 2022 (M2) MagSafe Port Replacement, Remove the lower case: 手順 7、 3の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Remove the lower case: 手順 7、 3の画像 2 MacBook Air 2022 (M2) MagSafe Port Replacement, Remove the lower case: 手順 7、 3の画像 3
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. MacBook Air 2022 (M2) MagSafe Port Replacement, Remove the battery connector cover: 手順 8、 1の画像 1
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
    • Due to screw variances, you may need to use a T4 Torx instead. Keep this in mind whenever you encounter T3 Torx screws during this repair.
  9. MacBook Air 2022 (M2) MagSafe Port Replacement: 手順 9、 2の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement: 手順 9、 2の画像 2
    • Remove the battery connector cover.
  10. MacBook Air 2022 (M2) MagSafe Port Replacement, Disconnect the battery: 手順 10、 2の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Disconnect the battery: 手順 10、 2の画像 2
    • Use an opening pick to pry up and disconnect the battery connector.
  11. MacBook Air 2022 (M2) MagSafe Port Replacement, Unfasten the top right press connector cover: 手順 11、 2の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Unfasten the top right press connector cover: 手順 11、 2の画像 2
    • Use a T3 Torx driver to remove the four 1.5 mm screws securing the top right press connector cover.
  12. MacBook Air 2022 (M2) MagSafe Port Replacement, Remove the top right press connector cover: 手順 12、 2の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Remove the top right press connector cover: 手順 12、 2の画像 2
    • Remove the top right press connector cover.
  13. MacBook Air 2022 (M2) MagSafe Port Replacement, Disconnect the MagSafe port: 手順 13、 2の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Disconnect the MagSafe port: 手順 13、 2の画像 2
    • Use the pointed end of a spudger to pry up and disconnect the MagSafe port press connector.
  14. MacBook Air 2022 (M2) MagSafe Port Replacement, Unfasten the MagSafe port: 手順 14、 2の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Unfasten the MagSafe port: 手順 14、 2の画像 2
    • Use a T3 Torx driver to remove the two 3.3 mm screws securing the metal wedge to the MagSafe port.
    • This wedge keeps the port secure in its recess.
    • Use a T5 Torx driver to remove the two 2.8 mm screws securing the MagSafe port to the frame.
  15. MacBook Air 2022 (M2) MagSafe Port Replacement, Remove the securing bracket: 手順 15、 3の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Remove the securing bracket: 手順 15、 3の画像 2 MacBook Air 2022 (M2) MagSafe Port Replacement, Remove the securing bracket: 手順 15、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use tweezers or your fingers to remove the wedge from the top of the MagSafe port.
  16. MacBook Air 2022 (M2) MagSafe Port Replacement, Remove the MagSafe port: 手順 16、 3の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Remove the MagSafe port: 手順 16、 3の画像 2 MacBook Air 2022 (M2) MagSafe Port Replacement, Remove the MagSafe port: 手順 16、 3の画像 3
    • Use tweezers or your fingers to remove the MagSafe port.
  17. MacBook Air 2022 (M2) MagSafe Port Replacement, Install your MagSafe port: 手順 17、 3の画像 1 MacBook Air 2022 (M2) MagSafe Port Replacement, Install your MagSafe port: 手順 17、 3の画像 2 MacBook Air 2022 (M2) MagSafe Port Replacement, Install your MagSafe port: 手順 17、 3の画像 3
    • Follow this step to install your MagSafe port.
    • The screws will be drawn toward the magnet in the port. You may need to use angled tweezers to hold the screws in place while tightening them.
    • Insert the port and partially tighten the two 2.8 mm‑long screws that secure its left edge.
    • Properly align the port and fully tighten its screws.
    • You can plug your charger in and use it to align the port, but make sure it's not plugged into power.
    • Put the wedge into place on top of the MagSafe port and partially tighten its two 3.3 mm‑long screws.
    • Push the wedge under the lip of the frame and fully tighten its screws.
終わりに
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
作成者
2人の作成者と共同で作成されました。
Spencer Day
メンバー登録日: 09/14/22
55,149 ポイント
408のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,410のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 27
過去 30 日: 128
今までの合計 1,338
