はじめに
このガイドを参照して、上部ケースを交換しましょう。
必要な工具と部品
スパッジャーの先端もしくは指先を使って、トラックパッドのリボンケーブルZIFソケット上の固定フラップを持ち上げます。
トラックパッドのリボンケーブルをAirの正面端に向けて、ソケットからまっすぐ引き抜きます。
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
36 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
7 件のコメント
I'm pretty experienced in dismantling/reassembling Aluminum MacBook Pros, plastic MacBooks, aluminum Powerbooks and various iBooks and this was not bad at all. Mostly just time-consuming.
I'm not sure I'd rate it as "difficult" for those with previous experience. The screw count is particularly low by comparison to other machines I've worked on, and there are only a few different types of screw.
The new top case arrived with the adhesives to re-secure the speakers, new screws to attach the trackpad, and the microphone was pre-installed.
Excellent guide, and a great help as always. Thanks!
I just repaired my mba after spilling some juice on it... I did it in about 2hours, i kept track of the screws in each step and i must say it wasn't difficult at all, and i have no experience with computer so.. Just be careful with some wires and when you disconnect the monitor but that's all. I'm so happy my mba works again! The upper case and the tools arrived very quick and with adhesives and some extra screws (much appreciated since the stock screws were kind of damaged and i had to break one) for the trackpad. Thanks ifixit!
Just completed the upper case replacement today due to a failed keyboard and also a failed touch pad (due to liquid damage). Took a few hours to take it apart (and be careful as I was doing it) found hardest part was keeping track of screws and parts. I ended up using plastic red/white Solo cups with the Step # written on each cup (so you don't confuse the screws per step). Undoing the retaining clips for ribbon wires was hardest part highly recommend using a spudger with a fine tip as these are very tiny parts.
The instructions were great. I used a white plastic ice-tray to hold the screws and fill each cube up sequentially. All you have to do, is work backwards through the recesses to where you started. No way to mix things up and hard to tip over.
