はじめに
Use this guide to replace the AirPort/Bluetooth card.
必要な工具と部品
この手順で使用する道具:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
27 の人々がこのガイドを完成させました。
4 件のコメント
Very helpful! Tweezers were helpful to connect the reconnect the antenna connectors
I'm getting a "Wifi: No hardware installed" with an X over the wifi icon in the Menu.
Even after I swapped the original Airport card with a second one. Neither one works. The original worked up until a short time ago. I hadn't used the Air for a few months, but when I started it up the Airport wasn't recognized.
Also, should mention that Bluetooth works fine.
Could it be the Airport cables?
Specs: 13" Air (2014) running Mojave 10.14.1
I use a Netgear router with a Macbook Air 13, and the internet is very slow with it, and the connection is always disconnected and back on.
