メインコンテンツにスキップ
MacBook Air 11" Early 2015 Right Speaker Replacement
必要な工具と部品
  1. MacBook Air 11" Early 2015 Right Speaker Replacement, Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    購入する
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2015 Right Speaker Replacement: 手順 2、 1の画像 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2015 Right Speaker Replacement, Battery Connector: 手順 3、 2の画像 1 MacBook Air 11" Early 2015 Right Speaker Replacement, Battery Connector: 手順 3、 2の画像 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Early 2015 Right Speaker Replacement, Battery: 手順 4、 1の画像 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  5. MacBook Air 11" Early 2015 Right Speaker Replacement: 手順 5、 1の画像 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air 11" Early 2015 Right Speaker Replacement, Right Speaker: 手順 6、 1の画像 1
    • Use the tip of a spudger to de-route the right speaker cable from the channel cut into the logic board.
  7. MacBook Air 11" Early 2015 Right Speaker Replacement: 手順 7、 1の画像 1
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • Pry upward from beneath the wires.
  8. MacBook Air 11" Early 2015 Right Speaker Replacement: 手順 8、 2の画像 1 MacBook Air 11" Early 2015 Right Speaker Replacement: 手順 8、 2の画像 2
    • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
    • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
  9. MacBook Air 11" Early 2015 Right Speaker Replacement: 手順 9、 1の画像 1
    • Remove the right speaker from the upper case.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,970 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,299のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 41
今までの合計 2,245
