はじめに
Use this guide to replace the I/O faceplate, including its integrated antennas, on your Mac mini Late 2014. On some models it may be possible to remove and install the I/O faceplate without removing the heat sink; in that case, feel free to skip the steps for heat sink removal (just be extra careful not to damage the I/O faceplate cables).
If you do remove the heat sink, be sure to apply a new layer of thermal compound before reassembling your Mac mini. Follow our thermal paste guide for instructions on cleaning and preparing the thermal surfaces and applying a new layer of thermal compound.
This guide was made with a Fusion Drive Mac mini, and may have more connectors and components than your model. Don't be alarmed if you're missing a hard drive or SSD connector!
必要な工具と部品
The bottom cover is clipped onto three screw posts.
Pry near, but not right on the screw posts.
Remove the following TR6 screws from the antenna plate:
Three 4.1 mm screws
Three 1.9 mm screws
Remove the two 12 mm T6 screws from the fan.
Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
この手順で使用する道具:Mac mini Logic Board Removal Tool$4.99
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
Remove the following screws securing the heat sink to the logic board:
Four 8.6 mm T8 Torx screws
One 2.9 mm T6 Torx screw
Remove the following T6 Torx screws from the I/O port antenna cables:
Three 2.8 mm screws with washers
One 3.4 mm screw
One 2.7 mm screw
3 の人々がこのガイドを完成させました。
