メインコンテンツにスキップ
Mac Pro Late 2013 Logic Board Replacement
必要な工具と部品
  1. Mac Pro Late 2013 Logic Board Replacement, Outer Case: 手順 1、 2の画像 1 Mac Pro Late 2013 Logic Board Replacement, Outer Case: 手順 1、 2の画像 2
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 Logic Board Replacement: 手順 2、 3の画像 1 Mac Pro Late 2013 Logic Board Replacement: 手順 2、 3の画像 2 Mac Pro Late 2013 Logic Board Replacement: 手順 2、 3の画像 3
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 Logic Board Replacement, Fan Assembly: 手順 3、 3の画像 1 Mac Pro Late 2013 Logic Board Replacement, Fan Assembly: 手順 3、 3の画像 2 Mac Pro Late 2013 Logic Board Replacement, Fan Assembly: 手順 3、 3の画像 3
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
    You don't have to remove the fan assy to get to the wifi board & card. It can be done with the fan assy still attached.
    Fat Mango - 返信
    Fat Mango is correct. That said. If you do pull the fan assembly note that the screws are all held in with blue Permatex and breaking them free takes a fair amount of effort. Getting a good set of Torx screwdrivers is a must.
    Jim WIlson - 返信
    Hey guys, what would happen if you only replace one card.. I have a D300 but the plan is to upgrade to D500 or D600. So If I can afford and install one instead of the pair would it increase something? or will it cause any conflict? I guess I don’t understand if I the Mac Pro has 2 D300 graphic cards that means each has 1GB? Same as If I would Install 1 D600 that would increase 3GB only? Thanks.
    marcotamayo - 返信
    D300 = 2GB each card. Very few apps uses two cards at the same time.
    Gio Cas -
    The (5) Screws are Apple part number 923-0713
    Steven Gier - 返信
  4. Mac Pro Late 2013 Logic Board Replacement: 手順 4、 2の画像 1 Mac Pro Late 2013 Logic Board Replacement: 手順 4、 2の画像 2
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 Logic Board Replacement: 手順 5、 1の画像 1
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
    On my Mac Pro (assembled mid-2017) these are T8 screws. In fact, there were no T7 screws anywhere in my machine.
    mark33 - 返信
    There was no bracket on top of the cable at all, so I got a bit confused, so I had to skip step 5 and 6.
    Rakesh - 返信
    On my machine, a TR7 worked to remove them due to the weird angle.
    Wilson Gaberino - 返信
  6. Mac Pro Late 2013 Logic Board Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 Logic Board Replacement: 手順 7、 2の画像 1 Mac Pro Late 2013 Logic Board Replacement: 手順 7、 2の画像 2
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 Logic Board Replacement: 手順 8、 1の画像 1
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
    You don't have to remove the fan assy to do the steps below. They can be done with the fan assy still attached.
    Fat Mango - 返信
  9. Mac Pro Late 2013 Logic Board Replacement, Lower Case: 手順 9、 3の画像 1 Mac Pro Late 2013 Logic Board Replacement, Lower Case: 手順 9、 3の画像 2 Mac Pro Late 2013 Logic Board Replacement, Lower Case: 手順 9、 3の画像 3
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
  10. Mac Pro Late 2013 Logic Board Replacement: 手順 10、 2の画像 1 Mac Pro Late 2013 Logic Board Replacement: 手順 10、 2の画像 2
    • Carefully lift the lower case up and remove it from the Mac Pro.
  11. Mac Pro Late 2013 Logic Board Replacement, Interconnect Board: 手順 11、 2の画像 1 Mac Pro Late 2013 Logic Board Replacement, Interconnect Board: 手順 11、 2の画像 2
    • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
  12. Mac Pro Late 2013 Logic Board Replacement: 手順 12、 3の画像 1 Mac Pro Late 2013 Logic Board Replacement: 手順 12、 3の画像 2 Mac Pro Late 2013 Logic Board Replacement: 手順 12、 3の画像 3
    • Gently separate the other side as well.
    • Flip the connector up and out of the way of the graphics card.
    • Repeat this procedure on the other graphics card.
  13. Mac Pro Late 2013 Logic Board Replacement: 手順 13、 1の画像 1
    • Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
    These are actually 6.0mm T8 Torx Screws. 12/07/2016.
    Todd - 返信
    Ended up being T9 screws for me.
    Nathaniel Wilson - 返信
    mark33 - 返信
    These are T8 screws in my 2013 Mac Pro.
    Sangers - 返信
    T8 screws for me, i did and edit to this step
    Steve McGinn - 返信
    Ended up being T15 screws on my machine
    Spencer Curtis - 返信
  14. Mac Pro Late 2013 Logic Board Replacement: 手順 14、 3の画像 1 Mac Pro Late 2013 Logic Board Replacement: 手順 14、 3の画像 2 Mac Pro Late 2013 Logic Board Replacement: 手順 14、 3の画像 3
    • Gently walk the interconnect board straight up off the logic board's slot connection.
    • It is recommended to lift one side and then the other.
    • Do not try to remove the interconnect board from the Mac Pro yet, as it is still connected to the IO board.
  15. Mac Pro Late 2013 Logic Board Replacement: 手順 15、 2の画像 1 Mac Pro Late 2013 Logic Board Replacement: 手順 15、 2の画像 2
    • Flip the interconnect board up and over, exposing the IO board data cable.
    • Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
  16. Mac Pro Late 2013 Logic Board Replacement: 手順 16、 2の画像 1 Mac Pro Late 2013 Logic Board Replacement: 手順 16、 2の画像 2
    • Use the flat end of a spudger to separate the other side of the IO board data cable.
    • Bend the cable out of the way and remove the interconnect board from the Mac Pro.
  17. Mac Pro Late 2013 Logic Board Replacement, Power Supply Assembly: 手順 17、 1の画像 1
    • Flip the Mac Pro back over and set it gently on a flat surface.
    • We recommend laying the Mac Pro on the corner of the heat sink and the two standoff screw posts that attach to the interconnect board.
  18. Mac Pro Late 2013 Logic Board Replacement: 手順 18、 2の画像 1 Mac Pro Late 2013 Logic Board Replacement: 手順 18、 2の画像 2
    • Remove the two 3.6 mm T5 Torx screws from the sides of the power supply cage (one on each side).
    those are t4 screws in my mac
    Andrzej Kiryluk - 返信
    T4s on mine, as well
    rwcinmsp - 返信
  19. Mac Pro Late 2013 Logic Board Replacement: 手順 19、 1の画像 1
    • Remove the power supply cage from the top of the power supply.
    • By removing this cage, you are exposing internal components of the power supply. Be very careful not to touch any of the power supply components or circuitry.
    • Be careful not to drop any screws or tools into the power supply, as this may damage the power supply.
  20. Mac Pro Late 2013 Logic Board Replacement: 手順 20、 1の画像 1
    • Remove the four 5.5 mm T8 Torx screws securing the power supply assembly to the Mac Pro.
  21. Mac Pro Late 2013 Logic Board Replacement: 手順 21、 1の画像 1
    • Remove the power supply assembly from the Mac Pro.
  22. Mac Pro Late 2013 Logic Board Replacement, Logic Board: 手順 22、 1の画像 1
    • Remove two 5.5 mm T8 Torx screws.
    Il est possible de les retirer aussi des le début une fois le “fond” rond du Mac pro retiré
    Chris - 返信
    Step 22 when reassembling, it helps not to fully tighten until you put the screws in from step 20.
    Mike Sheedy - 返信
  23. Mac Pro Late 2013 Logic Board Replacement: 手順 23、 1の画像 1
    • Remove four 12.8 mm T10 Torx screws from the CPU heat sink bracket.
    • Remove only the outer four of the eight screws.
    I cannot unscrew one of those because I appears that one of the elements in wich it is screwd underneath is loose and moving along with the screw, making this operation impossible. Anyone had this issue ?? Any solution ??
    benjaminmonnoyeur - 返信
    I had the same problem. These screws go into threaded inserts, which in turn are screwed into the heatsink. Both have threadlocker compound applied. So the threaded insert’s threadlocker gives up first, and the threaded insert unscrews from the heatsink. Remove all 4 screws, then with a pair of needle nose pliers, hemostat, or thin 7mm wrench, hold the insert steady and unscrew the screw from it.
    Chuck Fry - 返信
    Could I remove these screws and re-screw? I worry that remove them but I can’t re-use them?
    timmy123 -
    I had that problem, too, and I did it like Chuck Fry, with a thin wrench. Unfortunately one threaded insert was so tight that I slipped and a capacitor broke off. Can someone tell me what kind of capacitor I need? I can't find anything under the name listed above the capacitor. Thank you.
    Steph - 返信
    A way to avoid this situation is to ease the tension on the spring slowly and rotate the loosening of four screws a few turns at a time – when the tension is released equally the threaded inserts are more likely to stay in place.
    Steve Esser - 返信
    I had 2 of those double sided screws stuck like that. I carefully removed them from the motherboard using a small vice grip to hold one side, and a torx on the other. Then reinstalled them using locktite compound. Make sure the heat sink is flush to the motherboard in the same way that you found it, or the assembly will not fit back in the case correctly, indicating the CPU may not be securely attached. The result may be that you think you killed your mac when you turn in on again and just hear the fan spinning like crazy but no chime or boot sequence. If that happens, go back in, reset the double sided screws, and make sure the heatsink is flush. Worked for me.
    Sili_pepper - 返信
  24. Mac Pro Late 2013 Logic Board Replacement: 手順 24、 2の画像 1 Mac Pro Late 2013 Logic Board Replacement: 手順 24、 2の画像 2
    • At this point, the logic board is held onto the heat sink by thermal compound.
    • You may need to gently pry with a spudger to separate the logic board from the heat sink.
    • Be very careful not to bend and break the logic board.
    • Remove the logic board from the heat sink.
  25. Mac Pro Late 2013 Logic Board Replacement: 手順 25、 2の画像 1 Mac Pro Late 2013 Logic Board Replacement: 手順 25、 2の画像 2
    • Remove the inner four 12.8 mm T10 Torx screws from the CPU heat sink bracket.
    • Remove the CPU heat sink bracket.
    On my Mac Pro (assembled mid-2017) these screws are covered with a black sticker presumably to indicate tampering. If you did not know they were screws it would not be obvious. You have to just put the T10 driver right in the center and start turning; it quickly breaks through the sticker.
    mark33 - 返信
    Oh man. Thanks so much for that comment! I would have tried to use pliers!
    Trevor Standley - 返信
    Also remember to support the CPU (On the other side) while removing these screws. Mine CPU fell out from the other side while loosening.
    Daniel Wood - 返信
    On my MacPro there are no screws here. On the backside the place where the back of the screws should be are covered with stickers, but removing the stickers simply reveals a rivet. There’s no screw and seemingly no way to remove the CPU.
    rsproductions - 返信
    Je confirme, un sceau plastique noir protège les 4 vis. Il faut percer et dévisser au centre avec t9 pour moi
    Chris - 返信
    Wow, glad I clicked comments. I had no clue about the sticker. I was about to use some kind of something to get them out 😂
    Marc Kinnear - 返信
  26. Mac Pro Late 2013 Logic Board Replacement: 手順 26、 1の画像 1
    • Remove the second heat sink bracket.
  27. Mac Pro Late 2013 Logic Board Replacement: 手順 27、 2の画像 1 Mac Pro Late 2013 Logic Board Replacement: 手順 27、 2の画像 2
    • Lift and remove the logic board from the CPU and bracket.
    • During reassembly, be sure to clean off and replace the thermal compound on the CPU.
    • We have a thermal paste guide that makes replacing the thermal compound easy.
    There is one import piece of information when replacing or upgrading these processors. There are two possible orientations and only one is correct (correct me if I’m wrong!). There’s a small arrow on one corner of the processor that needs to be aligned to the correct side. Just match the orientation of the original processor - this can be difficult or easy to overlook since the tiny alignment arrow is usually covered with thermal paste. Clean the Thermal paste off the old processor before you remove it to see the correct alignment.
    Steve Esser - 返信
終わりに
11 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
503,085 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,299のガイドは作成済み
コメント 1 件
The RAM/CPU board is only attached to the thermal core around the processor area. This means seating RAM modules can flex the board (which has no support under the RAM sockets) so take extra care seating RAM modules.
john gilchrist - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 22
過去 30 日: 115
今までの合計 15,201
