はじめに
If your Mac Pro has a scratched or damaged case, here is a tutorial to completely replace it.
Anyone can do it, but the disassembly and reassembly are very long steps. Patience is the key to success.
必要な工具と部品
Lift the flap to put it in the unlocked position, the panel should separate from the box without forcing.
Then to remove the hard drives, pull them towards you with a bit of force.
On the power supply there is a button, press it to move the power supply to the left (see picture)
Then pull the graphics card towards you to take it out of the box
With a screwdriver unscrew the two screws that hold the fan bracket to the board
Pull the fan towards you
Behind the fan bracket there are 2 SATA cables, a 4 pin mini power supply and a 4 pin fan
With a H2.5 screwdriver, unscrew the screws on the bottom of the bracket (photo 2)
With a Phillips screwdriver, unscrew the screws on the bottom of the case (photo 3)
Disconnect the 2 x 4pin fan cables and the 1 x 2 pin speaker cable
Remove the ribbon that connects the motherboard to the expansion card (USB, Jack, Power Off etc.)
To resemble, follow the instructions in the reverse order.
21 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
7 件のコメント
Bonjour, j’ai un mac pro 5,1 de 2010 dont les clapets (ou les trappes, j’ignore le terme exact) de la baie des lecteurs de disques restent ouverts à chaque fois qu’ils sont actionnés. Je n’ai pas réussi à les démonter, et les 2 gouttes de 3 en 1 sur les glissières latérales n’ont rien changé au problème. Je n’ai trouvé aucun tutoriel, ni même aucune occurrence de ce problème sur le web. Pourriez-vous me donner quelques conseils ? Merci.
Amazing explanations and perfect picture track on each move made.
Thanks much - this was very helpful :)
Dennis.
Hello sir , I have a problem with my Mac Pro 5,1 mid 2010 Xeon 6core Cpu 64 GB Ram RX580
I erase SSD Hard Drive and I want to reinstall mojave OS and it does not work still appear ‘Missing Operating System’
I try to use all commends on startup like (Option) (Commend+R) (Option+Commend+R)(Option+Commend+R+P) and more commends
but nothing work with it … please I want help . I need your help please , please …
You’d probably get an answer a lot quicker if you just posted that as a question.
Thanks for posting this guide!
I used it to replace all the cooking fans in my macpro5,1. Worked great!!
