メインコンテンツにスキップ
MSI GT72 2QE Dominator Pro Battery Replacement
必要な工具と部品
  1. MSI GT72 2QE Dominator Pro Battery Replacement, Battery: 手順 1、 2の画像 1 MSI GT72 2QE Dominator Pro Battery Replacement, Battery: 手順 1、 2の画像 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a Phillips screwdriver to remove the seven 6mm screws from the bottom of the laptop.
    • Lift and remove the bottom case off of the laptop.
  2. MSI GT72 2QE Dominator Pro Battery Replacement: 手順 2、 2の画像 1 MSI GT72 2QE Dominator Pro Battery Replacement: 手順 2、 2の画像 2
    • Use a Phillips screwdriver to remove one 4 mm screw and one 10 mm screw from each fan.
    • The 10mm fan screw won't actually come out, as it is attached with rubber piece to fan. Unscrewing it from the lower case will allow for removal, though.
    • Unplug both fans by gently disconnecting the fan connector from its motherboard socket. If you have trouble, gently wiggle the connector to loosen it.
  3. MSI GT72 2QE Dominator Pro Battery Replacement: 手順 3、 1の画像 1
    • Unplug the SATA cable and remove the hard drive.
    • Make sure to pull cable straight out in order to ensure it stays intact.
  4. MSI GT72 2QE Dominator Pro Battery Replacement: 手順 4、 1の画像 1
    • Remove two 6mm Phillips #0 screws and remove the M.2 SSDs.
    • Make sure you pull SSD straight out so it doesn't get damaged.
  5. MSI GT72 2QE Dominator Pro Battery Replacement: 手順 5、 1の画像 1
    • Unplug both red and black speaker cables. Pull straight out so the connectors aren't damaged.
    • Disconnect both these cables carefully by lifting the pressure tabs then gently pulling.
  6. MSI GT72 2QE Dominator Pro Battery Replacement: 手順 6、 1の画像 1
    • Unplug the battery cable.
    • Pull straight up so as not to damage pins.
  7. MSI GT72 2QE Dominator Pro Battery Replacement: 手順 7、 1の画像 1
    • Remove 15 5mm Phillips #0 screws and remove inner case.
    • Case may take some force to remove, but don't apply excessive force or you risk breaking the plastic connector tabs.
  8. MSI GT72 2QE Dominator Pro Battery Replacement: 手順 8、 1の画像 1
    • Use a card or other flat object to lift and remove the battery from the housing.
    • Be extremely careful removing the battery. If punctured, hazardous chemicals can be released, or the battery could catch fire or even explode.
  9. MSI GT72 2QE Dominator Pro Battery Replacement: 手順 9、 1の画像 1
    • Replace the battery with a 11.1V, 7500mAh Li-ion battery, MSI part number: BTY-L77 or equivalent.
    • Run MSI Battery Calibration to make sure the firmware can see the new batteries cycle high low voltages.
終わりに
29 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Kevin Shipp
メンバー登録日: 04/18/17
950 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S17-G2, Banghart Spring 2017 Cal Poly, Team S17-G2, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S17G2
5 メンバー
7のガイドは作成済み
17 件のコメント
Hi,
on the steep 7, you forgot a screw : just above the orange part of the heat sink.
great guide otherwise :D
Assombrance Anderson - 返信
And another one near the bass speaker
Did it but I was left with one screw. Have no idea where it goes. But hey battery works and not complaining.
Andres Estrin - 返信
Anyone know where to find a GT72 Dominator battery?
Hunter Gronkowski - 返信
I bought mine here: http://www.fr-batterie.com/
Thanks for this tutorial!
I used it to replace my GT72 2QD Dominator battery. It’s almost the same (yet, not a piece of cake).
Cameron -
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 38
過去 30 日: 233
今までの合計 48,519
