はじめに
The heatsink is a piece of milled aluminum that passively cools the SoC on the CPU module. It needs to be removed to replace the CPU module.
Please note that removing the heatsink will require re-applying thermal paste.
必要な工具と部品
Remove the following screws securing the transparent acrylic bottom plate to the main box:
Ten M2×6mm silver Phillips screws
Remove the following screws securing the heatsink:
Four M2×12 Philips screws
To reassemble your device, re-apply new thermal paste and follow these instructions in reverse order.
Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
ある他の人がこのガイドを完成しました。
