はじめに
This replacement guide will show you how to replace the speaker for this device. It is a simple and easy procedure that we will show you how to do at home step by step.
必要な工具と部品
Separate the back of the device from the face by inserting the flat end of the nylon spudger into the corner of the device to safely pry it open.
Remove wires from the device with a solder iron. Use the soldering technique guide for helpful tips!
もう少しです!
終わりに
