必要な工具と部品
Use a metal spudger to pry open the power button cover.
Once the power button cover is slightly opened, use your fingers to remove the power button cover.
Remove the fifteen 13.0 mm screws with a #0 Phillips from the side of the device containing two speakers.
Separate the two halves by gently pulling them apart.
3 の人々がこのガイドを完成させました。
コメント 1 件
Could you recommend anywhere to find the correct replacement tweeters & drivers?
