メインコンテンツにスキップ
Logitech MX Master 3S Mouse Feet Replacement
必要な工具と部品
  1. Logitech MX Master 3S Mouse Feet Replacement, Soften the mouse feet adhesive: 手順 1、 3の画像 1 Logitech MX Master 3S Mouse Feet Replacement, Soften the mouse feet adhesive: 手順 1、 3の画像 2 Logitech MX Master 3S Mouse Feet Replacement, Soften the mouse feet adhesive: 手順 1、 3の画像 3
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to each of the mouse feet for about one minute each.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
    • The information sticker adhesive may soften during this step, but you don't need to remove it.
  2. Logitech MX Master 3S Mouse Feet Replacement, Separate the mouse foot adhesive: 手順 2、 3の画像 1 Logitech MX Master 3S Mouse Feet Replacement, Separate the mouse foot adhesive: 手順 2、 3の画像 2 Logitech MX Master 3S Mouse Feet Replacement, Separate the mouse foot adhesive: 手順 2、 3の画像 3
    • Slide an opening pick under an edge of the left mouse foot.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Peel up and remove the left mouse foot.
  3. Logitech MX Master 3S Mouse Feet Replacement, Remove the remaining feet: 手順 3、 3の画像 1 Logitech MX Master 3S Mouse Feet Replacement, Remove the remaining feet: 手順 3、 3の画像 2 Logitech MX Master 3S Mouse Feet Replacement, Remove the remaining feet: 手順 3、 3の画像 3
    • Repeat the previous two steps for the three remaining feet.
    • The front foot doesn't cover any screws—if you're only removing the mouse feet to open up the mouse, you don't need to remove this foot.
  4. Logitech MX Master 3S Mouse Feet Replacement, Reassembly information: 手順 4、 3の画像 1 Logitech MX Master 3S Mouse Feet Replacement, Reassembly information: 手順 4、 3の画像 2 Logitech MX Master 3S Mouse Feet Replacement, Reassembly information: 手順 4、 3の画像 3
    この手順で使用する道具:
    購入する
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • For installing new mouse feet or reusing your old ones:
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
125,037 ポイント
582のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,430のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 75
過去 30 日: 335
今までの合計 4,742
