はじめに
If you find yourself looking to replace your Logitech Harmony 1100 screen because it is cracked or malfunctioning, use this guide to help. Sometimes individual pixels can have issues that effect the entire display but this is likely just an issue with the screen and not the device. You will not need any spacial skills to complete this, only the tools listed.
必要な工具と部品
Remove the battery cover by pushing down on the circled areas and pushing outward.
Remove the battery by lifting up the battery on the corner exposed by the indent in the case
Pop out the plastic screen backing on front of device.
Loosen the screen backing by pushing back on the plastic clips that hold the screen backing in place.
3 の人々がこのガイドを完成させました。
