はじめに
Follow this guide to remove or replace the mouse feet (also called skates or pads) on your Logitech G502 Lightspeed.
If you plan to reuse the mouse feet, you’ll need to apply heat to loosen the adhesive and remove the feet with minimal bending. Bent or torn mouse feet may require replacement.
必要な工具と部品
Insert the tip of an opening pick underneath the front foot at the gap in its recess.
When possible, grab with your fingers and slowly pull to peel it off completely.
Insert the tip of an opening pick underneath the tiny front right foot at the gap in its recess.
Insert the tip of an opening pick underneath the rear foot starting at the gap in its recess.
Insert the tip of an opening pick underneath the left foot at the gap in its recess.
Insert the tip of an opening pick under the front point of the sensor foot. Keep the pick at a steep angle relative to the mouse to get under the foot's adhesive.
Remove the sensor foot.
2 の人々がこのガイドを完成させました。
3 件のコメント
Any recommendations where can I get new feet and adhesive?
You can use a double-sided tape or if you want to buy a replacement, look for G502 Lightspeed Rubber Feet on the aftermarket that sells it
Www.feetglide.com
Rex Luscus - 返信
