はじめに
Replacing the right joystick for the Logitech G Cloud is difficult and can be accomplished in seven steps. You will need a wedge tool, Phillips #00 screwdriver, and a spudger. Carefully read the instructions before starting to disassemble the Logitech G Cloud. You may hear loud popping noises when you remove the interior plating. Once the screws are removed, the joystick should be simple to pop out.
必要な工具と部品
Power the device off and turn it over so the screen is face down.
Insert an opening pick into the seam between the back plate and left handguard.
Pry around the entire perimeter until the handguard fully releases.
Remove the handguard.
Repeat the previous three bullets on the right handguard.
Use a spudger to lift upwards and disconnect the metallic sticker from the console.
Insert the flat end of a spudger under the joystick press connector and lift upwards to disconnect it.
Use a spudger to remove the R2 trigger sensor from the joystick plate; it should stay attached to the console.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
