メインコンテンツにスキップ
Logitech G Cloud Left Joystick Replacement
必要な工具と部品
  1. Logitech G Cloud Left Joystick Replacement, Case: 手順 1、 2の画像 1 Logitech G Cloud Left Joystick Replacement, Case: 手順 1、 2の画像 2
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
  2. Logitech G Cloud Left Joystick Replacement: 手順 2、 1の画像 1
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
  3. Logitech G Cloud Left Joystick Replacement: 手順 3、 2の画像 1 Logitech G Cloud Left Joystick Replacement: 手順 3、 2の画像 2
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
  4. Logitech G Cloud Left Joystick Replacement: 手順 4、 1の画像 1
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
  5. Logitech G Cloud Left Joystick Replacement: 手順 5、 2の画像 1 Logitech G Cloud Left Joystick Replacement: 手順 5、 2の画像 2
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
  6. Logitech G Cloud Left Joystick Replacement, Left Joystick: 手順 6、 2の画像 1 Logitech G Cloud Left Joystick Replacement, Left Joystick: 手順 6、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the two 10 mm screws that secure the L2 trigger.
    • Pop the L2 trigger out with your fingers.
  7. Logitech G Cloud Left Joystick Replacement: 手順 7、 3の画像 1 Logitech G Cloud Left Joystick Replacement: 手順 7、 3の画像 2 Logitech G Cloud Left Joystick Replacement: 手順 7、 3の画像 3
    • Use a spudger to lift upwards and disconnect the metallic sticker from the console.
    • The sticker should stay attached to the joystick plate.
    • Insert the flat end of a spudger under the joystick press connector and lift upwards to disconnect it.
    • Use a spudger to remove the L2 trigger sensor from the joystick plate; it should stay attached to the console.
  8. Logitech G Cloud Left Joystick Replacement: 手順 8、 2の画像 1 Logitech G Cloud Left Joystick Replacement: 手順 8、 2の画像 2
    • Use a Phillips #00 screwdriver to remove all three 10 mm screws that secure the joystick assembly.
    • Pop the joystick out with your fingers.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
作成者
3人の作成者と共同で作成されました。
Spencer Davis
メンバー登録日: 01/23/25
517 ポイント
6のガイドは作成済み
チーム
Western Carolina University, Team 1-1, Virtue Spring 2025 Western Carolina University, Team 1-1, Virtue Spring 2025人のメンバー
WCU-VIRTUE-S25S1G1
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 45
今までの合計 304
