メインコンテンツにスキップ
Lighting: Replacing Light Emitting Diode
必要な工具と部品
  1. Lighting: Replacing Light Emitting Diode, Light Emitting Diode: 手順 1、 1の画像 1
    • Using a plastic opening tool, remove the base of the Light Angel.
    • Insert the plastic opening tool between the base and the LED housing and pull outwards on the handle.
  2. Lighting: Replacing Light Emitting Diode: 手順 2、 1の画像 1
    • Using a Phillips head jeweler's screwdriver, remove the screw on the battery housing.
    • To remove the screw, turn counterclockwise.
    • Remember to put all the screws you take out somewhere safe so you can find them when it's time to reassemble the light.
  3. Lighting: Replacing Light Emitting Diode: 手順 3、 1の画像 1
    • Remove and set aside the (4) AA batteries in the battery housing.
  4. Lighting: Replacing Light Emitting Diode: 手順 4、 1の画像 1
    • Using a Phillips head jeweler's screwdriver, remove the (6) screws holding the LED housing together.
    • To remove the screws, turn counterclockwise.
  5. Lighting: Replacing Light Emitting Diode: 手順 5、 1の画像 1
    • Insert the plastic opening tool into the crease on the side of the LED housing to separate it from the rest of the device.
  6. Lighting: Replacing Light Emitting Diode: 手順 6、 1の画像 1
    • Locate the faulty light emitting diode on the back of the circuit board.
    • Using a soldering iron and desoldering braid, unsolder the connection on the light emitting diode.
    • Do not allow the soldering iron to come in contact with other components on the circuit board.
    • For detailed instructions on how to solder go to はんだ付けとはんだ除去の作業ガイド
  7. Lighting: Replacing Light Emitting Diode: 手順 7、 1の画像 1
    • Insert the new light emitting diode through the two holes left from removing the old one.
    • Note: the picture is not of the Light Angel circuit board. It is a general example of inserting a light emitting diode on a circuit board. Photo Credit: はんだ付けとはんだ除去の作業ガイド
  8. Lighting: Replacing Light Emitting Diode: 手順 8、 1の画像 1
    • Using solder and a soldering iron, solder the new LED to the circuit board.
    • Keep your solder joints separate to avoid short circuiting the circuit board.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Matthew Corigliano
メンバー登録日: 02/10/16
155 ポイント
1ガイドが承認済み
チーム
Colorado Springs, Team 8-6, Mcmichael Spring 2016 Colorado Springs, Team 8-6, Mcmichael Spring 2016人のメンバー
UCCS-MCMICHAEL-S16S8G6
3 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 18
過去 30 日: 73
今までの合計 6,042
