メインコンテンツにスキップ
Lens Replacement
必要な工具と部品
  1. Lens Replacement, Removing the Battery: 手順 1、 3の画像 1 Lens Replacement, Removing the Battery: 手順 1、 3の画像 2 Lens Replacement, Removing the Battery: 手順 1、 3の画像 3
    • Flip the small blue switch up to release the battery. Remove the battery.
    • Remove two Philips #000 screws. Place the screws on a magnetic pad or somewhere safe.
    • Insert a plastic opening tool in the corner by the Micro USB plug. This area will allow leverage in order to take off the outer case.
  2. Lens Replacement, Removing the Outer Casing: 手順 2、 3の画像 1 Lens Replacement, Removing the Outer Casing: 手順 2、 3の画像 2 Lens Replacement, Removing the Outer Casing: 手順 2、 3の画像 3
    • Use the opening tool and your fingers to pry apart the outer case. Hold back camera as well as menu navigation buttons while you remove the case.
    • Unscrew two small Phillips screws holding the outer case to the motherboard. Use the opening tool to unhook the case from the plate covering the motherboard.
    • The second screw (top left) is under the control PCB. The PCB is mounted to a metal plate that is retained by some adhesive tape underneath and two prongs (bottom-left). You need to pry the plate from the top-right until the tape is broken, then slide the plate upwards (relative to photo). Take care not to pull or tear the ribbon cable.
  3. Lens Replacement, Removing the Ribbon: 手順 3、 2の画像 1 Lens Replacement, Removing the Ribbon: 手順 3、 2の画像 2
    • Disconnect the button casing ribbon cable from the motherboard.
    • Be gentle when removing the ribbon.
    • Lift up the metal casing with one hand and use the other hand to snap the ZIF connector back, in order to remove the display ribbon cable.
  4. Lens Replacement, Replacing the Lens: 手順 4、 3の画像 1 Lens Replacement, Replacing the Lens: 手順 4、 3の画像 2 Lens Replacement, Replacing the Lens: 手順 4、 3の画像 3
    • Remove the display and buttons.
    • Release the clamp on the two ribbon cables connected to the camera lens.
    • Be gentle when removing the ribbons cables. They are fragile and can tear.
    • Pull the lens out of the camera base.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
salome datong
メンバー登録日: 09/26/16
104 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S14G4
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 20
今までの合計 1,035
