メインコンテンツにスキップ
Lenovo Yoga Book X90F Bottom Screen/Keyboard Replacement
必要な工具と部品
  1. Lenovo Yoga Book X90F Bottom Screen/Keyboard Replacement, Bottom Screen/Keyboard: 手順 1、 1の画像 1
    • Turn off and power down the device before beginning this process. A heat gun or hair dryer will be suitable to heat the adhesive that holds down the screen. Apply heat to the entire surface area of the bottom screen.
    • New adhesive will be required when completing the steps in reverse order.
  2. Lenovo Yoga Book X90F Bottom Screen/Keyboard Replacement: 手順 2、 2の画像 1 Lenovo Yoga Book X90F Bottom Screen/Keyboard Replacement: 手順 2、 2の画像 2
    • Once the adhesive has been heated up, take the iFixIt suction cup and lift in a corner. The screen should be separating from the adhesive here.
    • While the screen is lifted, insert the ifixit opening pick to help pry off the screen.
    • The screen may crack easily as it is thin and fragile.
  3. Lenovo Yoga Book X90F Bottom Screen/Keyboard Replacement: 手順 3、 1の画像 1
    • While the screen has been lifted, insert the plastic opening picks. Heat the adhesive and follow with the screen removal tool to ensure that you are not prying it apart with excessive force.
  4. Lenovo Yoga Book X90F Bottom Screen/Keyboard Replacement: 手順 4、 3の画像 1 Lenovo Yoga Book X90F Bottom Screen/Keyboard Replacement: 手順 4、 3の画像 2 Lenovo Yoga Book X90F Bottom Screen/Keyboard Replacement: 手順 4、 3の画像 3
    • After the screen has been opened, disconnect the ribbon connecting the bottom screen to the motherboard by gently pulling the ribbon with tweezers.
    • If there are black coverings on the tabs as shown in the second image, carefully remove them using a pair of tweezers.
    • You can find more information on Zero Insertion Force (ZIF) connectors on this guide.
  5. Lenovo Yoga Book X90F Bottom Screen/Keyboard Replacement: 手順 5、 1の画像 1
    • Separate and remove the bottom screen from the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Cristian Harris
メンバー登録日: 09/30/21
417 ポイント
2のガイドは作成済み
チーム
Clemson, Team 5-2, Hunter Fall 2021 Clemson, Team 5-2, Hunter Fall 2021人のメンバー
CLEM-HUNTER-F21S5G2
5 メンバー
6のガイドは作成済み
3 件のコメント
Was your keyboard cracked before you removed it? I see the first photo has an intact keyboard...
I've been given two of these, one with a dead keyboard and the other with a destroyed primary display. I want to transfer the functioning keyboard to the other intact machine. Is that possible, or will that destroy the keyboard?
Sam - 返信
Hi Sam, it looks like no one has replied - my answer would be that the keyboard will be destroyed. I had to remove the keyboard to replace the battery, and the guide on IFixit for that implied that the risk of removing the keyboard meant destroying it. So I accepted that risk, and now I am trying to source the [right] replacement keyboard. I was sent a Spanish language keyboard, which really isn't right for me and have said that to the seller and asked for the English version, but sadly they were out of stock. If you have found one please let me know!
Mark Rohde -
An addendum to my previous comment, this Youtube video suggests you might get away with it Sam! Probably requires the right heatgun (maybe not a hairdryer!) And patience...
https://youtu.be/LiFsHX98yiA
Mark Rohde -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 49
今までの合計 1,892
