メインコンテンツにスキップ
Lenovo Yoga 900-13ISK Left Daughterboard Replacement
必要な工具と部品
  1. Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Back Cover: 手順 1、 2の画像 1 Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Back Cover: 手順 1、 2の画像 2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Left Daughterboard Replacement: 手順 2、 3の画像 1 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: 手順 2、 3の画像 2 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: 手順 2、 3の画像 3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Battery: 手順 3、 3の画像 1 Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Battery: 手順 3、 3の画像 2 Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Battery: 手順 3、 3の画像 3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Left Daughterboard Replacement: 手順 4、 3の画像 1 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: 手順 4、 3の画像 2 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: 手順 4、 3の画像 3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
  5. Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Left Daughterboard: 手順 5、 3の画像 1 Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Left Daughterboard: 手順 5、 3の画像 2 Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Left Daughterboard: 手順 5、 3の画像 3
    • Remove the single 3.6 mm screw from the daughterboard with a Phillips #00 screwdriver.
  6. Lenovo Yoga 900-13ISK Left Daughterboard Replacement: 手順 6、 3の画像 1 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: 手順 6、 3の画像 2 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: 手順 6、 3の画像 3
    • Grabbing the outside edge of the daughterboard, flip the board up to reveal the ZIF connector on the underside.
  7. Lenovo Yoga 900-13ISK Left Daughterboard Replacement: 手順 7、 3の画像 1 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: 手順 7、 3の画像 2 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: 手順 7、 3の画像 3
    • Using a spudger, flip up the hinged locking tab of the ZIF connector on the underside of the daughterboard.
    • Pull the daughterboard away from the cable to disconnect.
終わりに
作成者
1人の作成者と共同作成されました。
Austin Blakely
メンバー登録日: 03/11/19
19,631 ポイント
53のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,299のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 401
