メインコンテンツにスキップ
Lenovo Yoga 900-13ISK Display Assembly Replacement
必要な工具と部品
  1. Lenovo Yoga 900-13ISK Display Assembly Replacement, Back Cover: 手順 1、 2の画像 1 Lenovo Yoga 900-13ISK Display Assembly Replacement, Back Cover: 手順 1、 2の画像 2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 2、 3の画像 1 Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 2、 3の画像 2 Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 2、 3の画像 3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Display Assembly Replacement, Battery: 手順 3、 3の画像 1 Lenovo Yoga 900-13ISK Display Assembly Replacement, Battery: 手順 3、 3の画像 2 Lenovo Yoga 900-13ISK Display Assembly Replacement, Battery: 手順 3、 3の画像 3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 4、 3の画像 1 Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 4、 3の画像 2 Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 4、 3の画像 3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
  5. Lenovo Yoga 900-13ISK Display Assembly Replacement, Display Assembly: 手順 5、 3の画像 1 Lenovo Yoga 900-13ISK Display Assembly Replacement, Display Assembly: 手順 5、 3の画像 2 Lenovo Yoga 900-13ISK Display Assembly Replacement, Display Assembly: 手順 5、 3の画像 3
    • Remove the ten 3.6 mm screws from the hinge bracket with a Phillips #00 screwdriver.
  6. Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 6、 3の画像 1 Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 6、 3の画像 2 Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 6、 3の画像 3
    • Use the pointed end of a spudger to lift the hinged locking flap of the display ZIF connector.
  7. Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 7、 2の画像 1 Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Pull out the display cable with a pair of blunt nose tweezers.
  8. Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 8、 3の画像 1 Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 8、 3の画像 2 Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 8、 3の画像 3
    • Open the laptop to a 45° angle, then close the laptop.
    • This raises the hinge, which will stay open as the bottom case is lowered.
  9. Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 9、 3の画像 1 Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 9、 3の画像 2 Lenovo Yoga 900-13ISK Display Assembly Replacement: 手順 9、 3の画像 3
    • Slide the bottom case away from the hinge.
    • If the hinge is catching on the case, either go back to the previous step and open the case a bit more, or manually open the hinge with your fingers.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Austin Blakely
メンバー登録日: 03/11/19
19,640 ポイント
53のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,303のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 845
