はじめに
This guide will show you how to remove the fingerprint reader.
必要な工具と部品
Remove seven Torx T5 short screws.
Remove three Torx T5 long screws.
This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
Remove four J1 Philips screws.
Remove one J1 philips screw.
Lift the battery slightly using your plastic opening tool.
6 の人々がこのガイドを完成させました。
コメント 1 件
Aiden,
How do I repair the power button on this model? It no longer clicks and I have to use a paper clip on the opposite side. Looks like I need to remove the motherboard to gain access
