はじめに
Use this guide to replace the lower case on your Lenovo Yoga 6 13ALC6.
Before you perform this repair, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
必要な工具と部品
Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
Insert an opening pick between the lower case and the chassis at a hinge corner.
Pry up with the pick to release the clips securing the lower case.
Repeat the process on the other hinge corner.
Slide the pick along the right edge to release the clips securing the lower case.
Continue sliding the opening pick along the front and left edges to release the remaining clips.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Lenovo Yoga answers community for help.
