はじめに
Is your laptop's trackpad not reacting when you use it? Then you will probably need to replace it and this guide will help you accomplish the task!
必要な工具と部品
Remove the eleven 6 mm T5 Torx screws securing the lower case.
Gently lift the lower case up and away from the device.
Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift up the black tab and the ribbon cable should come free.
ある他の人がこのガイドを完成しました。
