メインコンテンツにスキップ
Lenovo YOGA 730-15IKB Heat Sink Replacement
必要な工具と部品
  1. Lenovo YOGA 730-15IKB Heat Sink Replacement, Bottom Cover: 手順 1、 2の画像 1 Lenovo YOGA 730-15IKB Heat Sink Replacement, Bottom Cover: 手順 1、 2の画像 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 2、 2の画像 1 Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 2、 2の画像 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 3、 1の画像 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Heat Sink Replacement, Left Fan: 手順 4、 1の画像 1
    • When the laptop is upside down, the left fan is on the right side of the laptop near the wireless card and the SSD.
    • Remove the black and white antenna wires from the groove on the right side of the fan.
  5. Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 5、 2の画像 1 Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 5、 2の画像 2
    • Disconnect the fan cable. Pull the wire toward the right side of the laptop while wiggling to loosen the connection.
    • You can also use the white tabs on the connector to push the cable free.
  6. Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 6、 2の画像 1 Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 6、 2の画像 2
    • Remove two 4mm Phillips #1 screws.
  7. Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 7、 1の画像 1
    • Pull the fan up and towards the front of the laptop.
  8. Lenovo YOGA 730-15IKB Heat Sink Replacement, Right Fan: 手順 8、 1の画像 1
    • When the laptop is upside down, the right fan is on the left side of the laptop near the large metal RAM cover.
    • Disconnect the fan cable. Pull the wire toward the back of the laptop while wiggling to loosen the connection.
  9. Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 9、 2の画像 1 Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 9、 2の画像 2
  10. Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 10、 1の画像 1
  11. Lenovo YOGA 730-15IKB Heat Sink Replacement, Heat Sink: 手順 11、 3の画像 1 Lenovo YOGA 730-15IKB Heat Sink Replacement, Heat Sink: 手順 11、 3の画像 2 Lenovo YOGA 730-15IKB Heat Sink Replacement, Heat Sink: 手順 11、 3の画像 3
    • Remove three 4mm Phillips #1 screws.
    • Do not remove the springs that are attached to the screws.
  12. Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 12、 2の画像 1 Lenovo YOGA 730-15IKB Heat Sink Replacement: 手順 12、 2の画像 2
    • Pull the heat sink up to remove it from the motherboard.
    • If the heat sink is not lifting up easily, try using an opening tool to gently pry the heat sink away from the motherboard. The thermal paste on the underside of the heat sink may be sticking to the motherboard.
    • It is good practice to always apply new thermal paste before reattaching the heat sink. See this guide for more instructions on using thermal paste.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Ellis Ruckman
メンバー登録日: 01/23/20
2,545 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S1-G6, White Winter 2020 Cal Poly, Team S1-G6, White Winter 2020人のメンバー
CPSU-WHITE-W20S1G6
3 メンバー
27のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 17
今までの合計 1,358
