はじめに
Impact damage, water, overheating, and general wear and usage can cause the LCD panel to crack, develop missing pixels, or stop turning on. This guide shows how to replace the LCD panel within the Lenovo V14-IIL laptop. Be sure to remove small parts carefully.
Before using this guide, make sure to review the Lenovo V14-IIL troubleshooting page to review if there may be a solution that does not require component replacement.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
必要な工具と部品
Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
Using a Phillips #0 screwdriver, remove the six 2.2 mm screws from the hinges of the laptop.
Using a Phillips #0 screwdriver, remove the four 2.8 mm screws from the hinges and top corners of the laptop.
ある他の人がこのガイドを完成しました。
