はじめに
This guide will walk you through the process of removing the battery from your Lenovo ThinkPad X1 Carbon. This is an important step before performing any repairs or replacements in your laptop.
必要な工具と部品
Use a Phillips #1 screwdriver to loosen the five captive screws holding the back cover.
Insert an opening pick between a corner of the back cover and the chassis, near a hinge.
Pry upward to release the retaining clips.
Repeat this process for the opposite corner.
Insert the opening pick between the cover and the body.
Pry upward and release all of the retaining clips.
Use a Phillips #1 screwdriver to remove the six 4.9 mm screws securing the battery to the laptop chassis.
Grip the corners of the battery.
Pull and lift the battery of its recess and remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad X1 Carbon community for help.
