はじめに
If the touchpad on your Lenovo ThinkPad X1 Carbon (2nd Gen) lacks proper response, use this guide to replace it.
The touchpad is a control surface that allows you to move the cursor on your screen.
Before using this guide, check to make sure your touchpad driver is updated and clean off the touchpad surface.
Before you begin, make sure your computer is off.
必要な工具と部品
Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
ある他の人がこのガイドを完成しました。
