メインコンテンツにスキップ
Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement
必要な工具と部品
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Back Cover: 手順 1、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 2、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: 手順 3、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: 手順 3、 2の画像 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 4、 1の画像 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 5、 1の画像 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Fan: 手順 6、 1の画像 1
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 7、 1の画像 1
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 8、 1の画像 1
    • Remove the fan by lifting it directly up.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: 手順 9、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: 手順 9、 2の画像 2
    • Disconnect all 10 of the ribbon cables attached to the motherboard.
  10. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 10、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 10、 2の画像 2
    • Disconnect the wire connecting the motherboard to the speaker.
  11. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 11、 1の画像 1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding the metal covering over the power jack prongs.
  12. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 12、 1の画像 1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding down the Micro-SD card tray.
  13. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 13、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 13、 2の画像 2
    • Un-tape the orange and blue wires from the motherboard.
  14. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 14、 1の画像 1
    • Remove the black and grey wires from the cable comb on the motherboard.
  15. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 15、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 15、 2の画像 2
    • Use a Phillips #1 screwdriver to unscrew the 3.7mm screw holding down the wifi card.
    • Remove the wifi card.
  16. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 16、 2の画像 1 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: 手順 16、 2の画像 2
    • Carefully remove the motherboard by lifting it and pulling towards the left.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Eevee Murdock
メンバー登録日: 01/23/20
1,086 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S18-G4, White Winter 2020 Cal Poly, Team S18-G4, White Winter 2020人のメンバー
CPSU-WHITE-W20S18G4
4 メンバー
9のガイドは作成済み
2 件のコメント
All going as described, until the final step trying to pull the motherboard out, and there is something still holding it in place. With a bit of a wiggle and pull, there is something about near the screw hole that was holding the wifi card down preventing the card from lifting there. Any clues?
Tim Ellison - 返信
Answering my own question: Removing the motherboard requires that you first pop the SIM card / MicroSD card holder out of the socket, otherwise it won’t lift out. Submitted an update to the guide to save others falling into the same trap.
Tim Ellison -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 51
今までの合計 3,770
