はじめに
このガイドでは、Lenovo ThinkPad X1 Carbon 第6世代のバッテリーの取り外し方法と交換方法について説明します。ノートパソコンのバッテリーは、使用するにつれて容量が減少し、一般的なバッテリーは数年しか持ちません。 パソコンの調子が悪く、バッテリーに原因があると思われる場合は、 バッテリーの交換を始める前にトラブルシューティングペジを参照してください。 壊れた電源アダプタは問題を引き起こすころがあります。作業を始める前に、ラップトップの電源を切って、プラグから抜いてください。バッテリーを取扱う際は注意しながら、交換した後のバッテリーは正しく処理してください。
必要な工具と部品
Jimmyを使って、固定ピンから直接カバーをこじ開けて持ち上げます。
バックカバーを取り出します。
I thank you for these instructions. They were quite helpful and I successfully replaced the fan. There is one thing however. Your instructions stated the following: "Be sure to pull on all of the cables at the same time."
I disagree. One should never pull the wires. I was able to nudge the one part of the connector loose from the other part that it fit into." I then put the new fan in and gently and carefully pushed the connecting parts together.
Otherwise, your instructions were clear and to the point. Thank you very much
The image shows prying the cover open at the bottom right. In fact, there are tabs securing the bottom edge to the frame. The cover needs to be pried open at the top edge. Once the top edge is released, the cover can be shifted slightly toward the top of the image to disengage the tabs at the bottom.
This error, along with the similar error about removing the battery in step 4, suggests that the instructions were written with the laptop in the opposite orientation than what is shown in the images.
I also don't believe that the iFixit Jimmy is necessary - in fact, it might scratch up the exterior paint of the X1 Carbon Gen 6. Instead, I find the triangular iFixit picks are more appropriate for the task: iFixit Opening Picks (Set of 6)
Also, at least for my unit, the lid comes off easily and I only use the plastic picks if there's any resistance and I don't want to risk breaking any of the clips.
#0 プラスドライバーを使って、ラップトップフレームに留められたバッテリーを固定している長さ5mmのネジを4本外します。
The screw holes do not align 100%. Dont tighten all the screws as you re-insert them, leave just a little bit of play so that you can push the battery slightly until all the screws fit nicely, then tighten them. A little bit of DIY wisdom helps here. :-)
ラップトップの上部端からバッテリーをゆっくりと持ち上げて、マザーボードからバッテリーを引き抜きます。
Recommend changing the command language to lifting from the TOP edge, as the BOTTOM edge is secured.
Thank you, was wondering what I'm doing wrong
Agreed, the original description is misleading at best, wrong at worst!
In my 6th generation X1 Carbon there are two wires that are routed on the edge of the battery and have to be moved out of the way. These are antenna cables, be gentle with them, kinks and indents change their high frequency properties and may lead to problems with your WIFI.
How do I know the generation of my X1 Carbon?
Does this batter fit all generations?
The generation info of Lenovo ThinkPad X1 Carbon is marked on the back cover (i.e., 6th Generation), with shiny black color (ink ?), near the fan's openings.
The battery's original PN for 6th gen is ASM P/N SB10K97587 (FRU P/N 01AV430), marked visible on the battery (after removing the back cover).
The #0 Phillips screwdriver furnished with the kit was not well machined; it threatened to strip out the Phillips cross-grooves.
Fortunately, in my own toolbox I had a robust and well machined #0 screwdriver, and was able to remove the battery screws without stripping the grooves.
Otherwise, the kit was excellent.
Roger Mehle - 10/23/23
Hi @rogermehle, I'm very sorry to hear about the Phillips #0 screwdriver trouble. If you would like to reach out to our Customer Support team via help.ifixit.com, they will be able to assist you. Thank you for letting us know. We're happy your repair was a success overall : )
Yes top edge lift. Can't they change this?
このデバイスを再組み立てするには、インストラクションを逆の順番に従って作業を進めてください。
23 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
9 件のコメント
Does it require to switch off battery in BIOS first?
My work wanted to e-waste my 3 year-old ThinkPad. Bought the replacement battery here, followed the instructions—it works fine now. Thanks a lot.
danke )) ))
Great guide, and what an easy laptop to work on!!!
Step 4 is wrong.
You cannot pull the battery out on bottom edge because of the grey plastic arresting aids which you can see in the picture of step 3.
You first have to slide the battery as far as possible to the bottom edge into these grey parts so that the plug connection on top gets lose slightly and then carefully pull it out on side of the mainboard connector.
Also you do not need that Jimmy in step 2. After removing the screws just pull and lift the base cover with your fingers from the area where the hinges are located and then it easily slips out at the front.
100%
Thank you Frank
Ian Chin -
Hello.
You need to disconnect the PC electrically, and disable the battery in the BIOS prior to proceed to its replacement.
This will prevent electric shock or damage to the mainboard.
The battery will be automatically re-enabled when you plug in the DC charger.
does it matter if my battery model number is different from this replacement part number? mine is 01AV494
