メインコンテンツにスキップ
Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement
必要な工具と部品
  1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Bottom Cover: 手順 1、 2の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Bottom Cover: 手順 1、 2の画像 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 2、 3の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 2、 3の画像 2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 2、 3の画像 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 3、 2の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 3、 2の画像 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Battery: 手順 4、 2の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Battery: 手順 4、 2の画像 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 5、 3の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 5、 3の画像 2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 5、 3の画像 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Speaker: 手順 6、 3の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Speaker: 手順 6、 3の画像 2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Speaker: 手順 6、 3の画像 3
    • Disconnect the speaker cable from the motherboard using a connector puller or spudger.
  7. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 7、 2の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 7、 2の画像 2
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
  8. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 8、 3の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 8、 3の画像 2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 8、 3の画像 3
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
  9. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 9、 3の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 9、 3の画像 2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 9、 3の画像 3
    • Use the spudger to disconnect the hall sensor connector.
  10. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 10、 3の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 10、 3の画像 2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 10、 3の画像 3
    • Lift the speakers up.
    • Disconnect the cable speakers from the routing.
    • Remove the speakers from the system.
  11. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, SD Card Reader/Audio Card: 手順 11、 3の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, SD Card Reader/Audio Card: 手順 11、 3の画像 2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, SD Card Reader/Audio Card: 手順 11、 3の画像 3
    • Use a spudger to lift up the retaining flap on the SD card reader/audio card connector.
  12. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 12、 2の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 12、 2の画像 2
    • Use the spudger to remove the cable from the connector.
    • The cable is attached to the board with adhesive so you will need to peel the cable up.
  13. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 13、 2の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 13、 2の画像 2
    • Use the Phillips #1 screwdriver to remove two 3.1 mm screws from the card.
  14. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 14、 3の画像 1 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 14、 3の画像 2 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: 手順 14、 3の画像 3
    • Lift the SD card reader/audio card from the system by sliding it out from the socket.
    • You will need to slide the audio card ribbon cable under the coin cell battery cable to remove the SD card reader from the system.
終わりに
作成者
1人の作成者と共同作成されました。
Sarah Westberg
メンバー登録日: 03/11/19
23,378 ポイント
70のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,432のガイドは作成済み
コメント 1 件
It is not necessary to do steps 8 & 9.
K CHOI - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 67
今までの合計 1,529
