メインコンテンツにスキップ
Lenovo ThinkPad T480 Wi-Fi Card Replacement
必要な工具と部品
  1. Lenovo ThinkPad T480 Wi-Fi Card Replacement, External Battery: 手順 1、 2の画像 1 Lenovo ThinkPad T480 Wi-Fi Card Replacement, External Battery: 手順 1、 2の画像 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 2、 3の画像 1 Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 2、 3の画像 2 Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 2、 3の画像 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Wi-Fi Card Replacement, Back Cover: 手順 3、 2の画像 1 Lenovo ThinkPad T480 Wi-Fi Card Replacement, Back Cover: 手順 3、 2の画像 2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 4、 3の画像 3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 Wi-Fi Card Replacement, Internal Battery: 手順 5、 2の画像 1 Lenovo ThinkPad T480 Wi-Fi Card Replacement, Internal Battery: 手順 5、 2の画像 2
    • Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
  6. Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 6、 3の画像 1 Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 6、 3の画像 2 Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 6、 3の画像 3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 7、 3の画像 1 Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 7、 3の画像 2 Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 7、 3の画像 3
    • Using the black nylon spudger, wedge the battery up from the case and lift it out.
  8. Lenovo ThinkPad T480 Wi-Fi Card Replacement, Wi-Fi Card: 手順 8、 1の画像 1
    • Using the Phillips #1 screwdriver, remove the single 3.6 mm screw at the top of the Wi-Fi card attaching it to the motherboard.
  9. Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 9、 2の画像 1 Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 9、 2の画像 2
    • Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable off of the Wi-Fi card.
    • Be careful as you pry the cables off of the Wi-Fi card as they are fragile and easily damaged.
  10. Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 10、 2の画像 1 Lenovo ThinkPad T480 Wi-Fi Card Replacement: 手順 10、 2の画像 2
    • Slide the Wi-Fi card out from the slot to remove it from the board.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sarah Westberg
メンバー登録日: 03/11/19
24,109 ポイント
71のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
141 メンバー
17,895のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 48
過去 30 日: 210
今までの合計 5,443
