メインコンテンツにスキップ
Lenovo ThinkPad T470s Motherboard Replacement
必要な工具と部品
  1. Lenovo ThinkPad T470s Motherboard Replacement, Bottom Panel: 手順 1、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
  2. Lenovo ThinkPad T470s Motherboard Replacement, Batteries: 手順 2、 3の画像 1 Lenovo ThinkPad T470s Motherboard Replacement, Batteries: 手順 2、 3の画像 2 Lenovo ThinkPad T470s Motherboard Replacement, Batteries: 手順 2、 3の画像 3
    • Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
    • Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
    • Peel back connecting supporting tape on each of the batteries.
  3. Lenovo ThinkPad T470s Motherboard Replacement: 手順 3、 3の画像 1 Lenovo ThinkPad T470s Motherboard Replacement: 手順 3、 3の画像 2 Lenovo ThinkPad T470s Motherboard Replacement: 手順 3、 3の画像 3
    • Slide the upper battery out of the device, away from the laptop.
    • Slide the lower battery out of the device, away from the laptop.
  4. Lenovo ThinkPad T470s Motherboard Replacement, Fan and Heat Sink: 手順 4、 1の画像 1
    • Loosen the four screws from the heatsink with a Phillips #000 screwdriver.
  5. Lenovo ThinkPad T470s Motherboard Replacement: 手順 5、 1の画像 1
    • Unplug the fan from the motherboard.
  6. Lenovo ThinkPad T470s Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the heatsink and fan from the laptop.
  7. Lenovo ThinkPad T470s Motherboard Replacement: 手順 7、 1の画像 1
    • Wipe off the old thermal paste with either 99% isopropyl alcohol or kimwipes.
  8. Lenovo ThinkPad T470s Motherboard Replacement: 手順 8、 2の画像 1 Lenovo ThinkPad T470s Motherboard Replacement: 手順 8、 2の画像 2
  9. Lenovo ThinkPad T470s Motherboard Replacement, Wi-Fi Card: 手順 9、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the Wi-Fi card.
    • The Wi-Fi card will lift to a slight angle after the screw is removed.
  10. Lenovo ThinkPad T470s Motherboard Replacement: 手順 10、 1の画像 1
    • Grip the Wi-Fi card on both sides, then pull it directly out of its port.
  11. Lenovo ThinkPad T470s Motherboard Replacement, USB Board: 手順 11、 2の画像 1 Lenovo ThinkPad T470s Motherboard Replacement, USB Board: 手順 11、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the two 3.3 mm screws.
  12. Lenovo ThinkPad T470s Motherboard Replacement: 手順 12、 1の画像 1
    • Use your fingernail to flip up the gate, then pull the connector directly out of the port.
  13. Lenovo ThinkPad T470s Motherboard Replacement: 手順 13、 1の画像 1
    • Lift the USB board up and out of the chassis.
  14. Lenovo ThinkPad T470s Motherboard Replacement, SSD: 手順 14、 2の画像 1 Lenovo ThinkPad T470s Motherboard Replacement, SSD: 手順 14、 2の画像 2
    • Locate the SSD slot between the large battery and fan.
    • Remove the screw securing the SSD using a Phillips #000 screwdriver.
  15. Lenovo ThinkPad T470s Motherboard Replacement: 手順 15、 2の画像 1 Lenovo ThinkPad T470s Motherboard Replacement: 手順 15、 2の画像 2
    • Slide the SSD out of the motherboard.
  16. Lenovo ThinkPad T470s Motherboard Replacement, Motherboard: 手順 16、 2の画像 1 Lenovo ThinkPad T470s Motherboard Replacement, Motherboard: 手順 16、 2の画像 2
    • Flip up the locking gate, then pull the cable directly out of its port.
    • Use a Phillips #0 screwdriver to remove the single 3.3 mm screw on the top right corner of the motherboard.
  17. Lenovo ThinkPad T470s Motherboard Replacement: 手順 17、 1の画像 1
    • Remove the single 3.3 mm screw with a Phillips #0 screwdriver.
  18. Lenovo ThinkPad T470s Motherboard Replacement: 手順 18、 1の画像 1
  19. Lenovo ThinkPad T470s Motherboard Replacement: 手順 19、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw.
  20. Lenovo ThinkPad T470s Motherboard Replacement: 手順 20、 2の画像 1 Lenovo ThinkPad T470s Motherboard Replacement: 手順 20、 2の画像 2
    • Disconnect the speaker connection covering the screw.
    • Use a Phillips #0 screwdriver to remove the single 5 mm screw securing the motherboard.
  21. Lenovo ThinkPad T470s Motherboard Replacement: 手順 21、 1の画像 1
    • Remove the 3.3 mm screw using a Phillips #0 screwdriver.
  22. Lenovo ThinkPad T470s Motherboard Replacement: 手順 22、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the 3.3 mm screw.
  23. Lenovo ThinkPad T470s Motherboard Replacement: 手順 23、 1の画像 1
  24. Lenovo ThinkPad T470s Motherboard Replacement: 手順 24、 2の画像 1 Lenovo ThinkPad T470s Motherboard Replacement: 手順 24、 2の画像 2
    • Gently grip the motherboard and slide it to the right to remove the USB ports from the chassis.
    • You will hear an audible clicking sound.
    • Lift the motherboard up and out of the chassis.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Adam Soumayah
メンバー登録日: 02/15/22
217 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 25
過去 30 日: 113
今までの合計 2,548
