メインコンテンツにスキップ
Lenovo ThinkPad T470 SSD Replacement
必要な工具と部品
  1. Lenovo ThinkPad T470 SSD Replacement, External Battery: 手順 1、 3の画像 1 Lenovo ThinkPad T470 SSD Replacement, External Battery: 手順 1、 3の画像 2 Lenovo ThinkPad T470 SSD Replacement, External Battery: 手順 1、 3の画像 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 SSD Replacement: 手順 2、 3の画像 1 Lenovo ThinkPad T470 SSD Replacement: 手順 2、 3の画像 2 Lenovo ThinkPad T470 SSD Replacement: 手順 2、 3の画像 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 SSD Replacement, Bottom Cover: 手順 3、 2の画像 1 Lenovo ThinkPad T470 SSD Replacement, Bottom Cover: 手順 3、 2の画像 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 SSD Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad T470 SSD Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad T470 SSD Replacement: 手順 4、 3の画像 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 SSD Replacement: 手順 5、 1の画像 1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 SSD Replacement, SSD Assembly: 手順 6、 2の画像 1 Lenovo ThinkPad T470 SSD Replacement, SSD Assembly: 手順 6、 2の画像 2
    • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
  7. Lenovo ThinkPad T470 SSD Replacement: 手順 7、 2の画像 1 Lenovo ThinkPad T470 SSD Replacement: 手順 7、 2の画像 2
    • Use the flat end of a spudger to separate the connector from its socket.
  8. Lenovo ThinkPad T470 SSD Replacement: 手順 8、 3の画像 1 Lenovo ThinkPad T470 SSD Replacement: 手順 8、 3の画像 2 Lenovo ThinkPad T470 SSD Replacement: 手順 8、 3の画像 3
    • Grab the tab on the left side of the SSD assembly, and pull up to remove it from the laptop.
  9. Lenovo ThinkPad T470 SSD Replacement, SSD: 手順 9、 3の画像 1 Lenovo ThinkPad T470 SSD Replacement, SSD: 手順 9、 3の画像 2 Lenovo ThinkPad T470 SSD Replacement, SSD: 手順 9、 3の画像 3
    • Use your fingers to detach the plastic bracket from the SSD assembly.
  10. Lenovo ThinkPad T470 SSD Replacement: 手順 10、 2の画像 1 Lenovo ThinkPad T470 SSD Replacement: 手順 10、 2の画像 2
    • Flip the SSD assembly over so that the green connector board is visible.
  11. Lenovo ThinkPad T470 SSD Replacement: 手順 11、 2の画像 1 Lenovo ThinkPad T470 SSD Replacement: 手順 11、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the two 4 mm screws from the metal bracket.
  12. Lenovo ThinkPad T470 SSD Replacement: 手順 12、 3の画像 1 Lenovo ThinkPad T470 SSD Replacement: 手順 12、 3の画像 2 Lenovo ThinkPad T470 SSD Replacement: 手順 12、 3の画像 3
    • Use your hands to lift the metal bracket up and away from the SSD assembly.
    • There may be some adhesive attaching the metal bracket to the SSD.
  13. Lenovo ThinkPad T470 SSD Replacement: 手順 13、 1の画像 1
    • Remove the single 4 mm screw using a Phillips #1 screwdriver.
  14. Lenovo ThinkPad T470 SSD Replacement: 手順 14、 2の画像 1 Lenovo ThinkPad T470 SSD Replacement: 手順 14、 2の画像 2
    • Use the flat end of a spudger to pry the SSD up slightly and pull it out of the slot with your other hand.
  15. Lenovo ThinkPad T470 SSD Replacement: 手順 15、 2の画像 1 Lenovo ThinkPad T470 SSD Replacement: 手順 15、 2の画像 2
    • Remove the two 4 mm screws from the SSD connector board using a Phillips #1 screwdriver.
  16. Lenovo ThinkPad T470 SSD Replacement: 手順 16、 2の画像 1 Lenovo ThinkPad T470 SSD Replacement: 手順 16、 2の画像 2
    • Use your hand to remove the SSD connector board from the metal enclosure.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Kristen Gismondi
メンバー登録日: 11/12/14
92,093 ポイント
241のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,455のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 24
過去 7 日: 134
過去 30 日: 445
今までの合計 21,281
