はじめに
Use this guide to replace the smart card reader in a Lenovo ThinkPad T460.
The smart card reader’s job is to read a smart card, which is a device used to store data and provide login authentication.
If you cannot retrieve data or log in to your laptop using a smart card, or if you are experiencing error messages when using a smart card, you may need to replace your laptop’s smart card reader.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
必要な工具と部品
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Use a pair of blunt nose tweezers to pull the black connector out of its socket.
Remove two 5 mm screws from the speaker in the lower right-hand corner using a Phillips #1 screwdriver.
ある他の人がこのガイドを完成しました。
